Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > JTAG-PRO aka GPGJTAG
Old 05-09-2013, 17:13   #1 (permalink)
Guilherme Lima's Avatar
Member: 1508533
Thanks Meter: 45
Help pinnout with Samsung s5380[Answered/Solved]
Need procedure on GPG JTAG to repair dead boot. have a S5380 and I not know repair.
Old 05-10-2013, 07:13   #2 (permalink)
taoujdate's Avatar
Member: 510826
Thanks Meter: 183
Open soft select S5380
Solder pinout
Set Default Pinout
Erase , Select flash file S5380 Boot File :
Write
The Following User Says Thank You to taoujdate For This Useful Post:
Old 05-10-2013, 15:44   #3 (permalink)
Member: 1508533
Thanks Meter: 45
Thanks for the info, but does anyone have one flash boot version S5380B, S5380'm using, it would be the same?
Old 05-10-2013, 17:31   #4 (permalink)
jatchaminda's Avatar
Member: 661090
Sonork: 100.1616818
Thanks Meter: 541
you have to try
Originally Posted by Sniper_04 View Post
test it
-full erase
-select my fulldump
-set size to 4mb only
-tick write
-put your phone in DL mode by pressing combination key or USB jig
-flash your phone
-repair IMEI
Best Regards
Asela
The Following User Says Thank You to jatchaminda For This Useful Post:
Old 05-10-2013, 19:21   #5 (permalink)
Member: 1508533
Thanks Meter: 45
Okay, I'll try this procedure. But the version of the device is S5380B, will have some results pass this S5830D?
Old 05-10-2013, 20:49   #6 (permalink)
Member: 1508533
Thanks Meter: 45
The procedure did not work, did as he said but did not go into download mode. What can I try now?
Old 05-12-2013, 11:10   #7 (permalink)
Member: 661090
Sonork: 100.1616818
Thanks Meter: 541
please check which model written on pcb
did you try to write S5380 boot file ?
Best Regards
Asela
Old 05-16-2013, 18:36   #8 (permalink)
Member: 1508533
Thanks Meter: 45
I tried to update the boot with versions S5380 and S5380D and nothing to get into download mode. It remains now I try with version S5380B, but do not think anywhere, any solution?
Old 05-16-2013, 18:52   #9 (permalink)
Member: 1508533
Thanks Meter: 45
Now it seems that gave a light here, the phone is being recognized by the computer, but as USB DEVICE and not to install any drivers. What is this?
Old 05-22-2013, 07:00   #10 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
Hi
Did You Try To insert USB JIgs To Force Download Mode?
BR,
BEHBOODI
Old 05-22-2013, 21:16   #11 (permalink)
Member: 1508533
Thanks Meter: 45
I have the USB Jig, has another way? And this phone is your operating system Bada, Jig is only for Android or not?
Old 05-23-2013, 07:59   #12 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
JIG work on all whatever android or bada or something else..
may i know phone history ?
Old 05-23-2013, 14:59   #13 (permalink)
Member: 1508533
Thanks Meter: 45
Was removing the security code of the phone making a flash with Multiuploader when given an error on my PC and ended the procedure, then the phone is not connected nor in download mode more.
Old 05-23-2013, 18:44   #14 (permalink)
Member: 1508533
Thanks Meter: 45
The log operations
Erase operation(Make sure to press Power on key)...
CPU ID: 7F61B307.
Flash ID: 00EC0050 (512M).
Release Power on key now and operation continues...
Erase succeed!
Time: 11 s
Writing in progress(make sure to press Power On key)...
CPU ID: 7F61B307.
Write succeed!
Time: 8 s
Old 05-25-2013, 08:52   #15 (permalink)
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Read dump from ok phone and write to your phone..
and if i get phone in my shop i will read and upload for you.
The Following User Says Thank You to Rahul_Bhutani For This Useful Post:
Page generated in 0.20201 seconds with 9 queries
