Unlock Server
Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > JTAG-PRO aka GPGJTAG
Old 06-23-2012, 09:52   #1 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
need help I9000 write succeed but no response in PC(answered/Solved).
Writing in progress(make sure to press Power On key)...
CPU ID: 7704A01B.
Flash ID: 00EC0050 (512M).
Release Power on key now and operation continues...
Write succeed!
Time: 5 s
can you give me the right firmware of this phone?
Please..
Old 06-23-2012, 10:00   #2 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Please..
Hi
please use the USB JIg.
BR,
BEHBOODI
The Following User Says Thank You to BEHBOODI For This Useful Post:
Old 06-23-2012, 10:00   #3 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Red face
Connecting box...
Version: V3.0
SN: 00000002122
Port: COM26
Please press Power On key before any Read/Write/Erase operation.
PIN1 = VCC
PIN2 = TRST
PIN3 = TDI
PIN4 = TMS
PIN5 = TCK
PIN7 = TDO
PIN8 = SYSRST
Setting definition...
Set definition done!
Read operation(Make sure to press Power on key)...
CPU ID: 7704A01B.
File saved inE:\Wind0ws file\CellphoneShopRepair file\JTAG-PRO file\Dead-boot firmware\I9000\i9000newbackup.bin
Read succeed!
Time: 20 s
Erase operation(Make sure to press Power on key)...
CPU ID: 7704A01B.
Erase succeed!
Time: 3 s
CPU ID: 7704A01B.
Write succeed!
Time: 9 s
CPU ID: 7704A01B.
Write succeed!
Time: 9 s
This is the full logs of this phone..
Please i need help to solve this problem..
The history of this phone is PATERN LOCK after flash odin dead..
Try to recover in JTAG but after write flash phone no response in my PC.
need help.
Old 06-23-2012, 10:03   #4 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Originally Posted by .:**********:. View Post
Hi
BR,
BEHBOODI
Hi..
What is USB Jig? can you explain it to me bro?
I insert already USB but no response in my PC.
Old 06-23-2012, 10:15   #5 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Hi..
try this files
I9000_PDA - Downloads - GPGIndustries - Forum
BR,
BEHBOODI
Old 06-23-2012, 10:22   #6 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
i try that file already.. not solved..
Old 06-23-2012, 10:55   #7 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
I think this file can solve your problem tested files.
GPGJtag SAMSUNG_i9000_A_Boot.bin - Downloads - GPGIndustries - Forum
BR,
BEHBOODI
Old 06-23-2012, 11:43   #8 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
BR,
BEHBOODI
i tried this file, write success but still same problem.. i want it to know bro how to make USB Jigs on this phone can you help me?
This phone dead after flash odin and trying to recover using JTAG but after flash phone no response even in Download mode..
can you share it to me how to put in download mode in this phone?
Old 06-23-2012, 11:59   #9 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
check this
http://forum.gsmhosting.com/vbb/f606...ution-1149169/
BR,
BEHBOODI
Old 06-23-2012, 12:35   #10 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Wink
Thanks bro ill post the result tom..
Old 06-23-2012, 18:20   #11 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Hi..
simple diagram...
important tools and partner of jtag box
Old 06-24-2012, 09:17   #12 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Wink finaly i made it.
Successfully repaired I9000 deadboat..
CPU ID: 7704A01B.
Write succeed!
Time: 8 s
But i still have problem Unknown IMEI:
Any idea bro how to repair the IMEI?
BR.
Old 06-24-2012, 10:32   #13 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Wink SUCCESS...SUCCESS...Yahooo..All done. Phone back to normal.:D
Solution: First is flash it again in Odin3 in the right firmware after you PASS..
open Octopus and do imei fix..
See this.
All done and phone is back to normal..
thank's to BEHBOODI for the support.
By the way i used this as a USB Jigs, i made this with the resistor of 300k and works perfect.
@mods please edit the tittle of this thread into (Problem Solved.)
BR.
The Following User Says Thank You to DEADBOOT For This Useful Post:
Old 06-24-2012, 12:51   #14 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
@ emilTECH
Good job bro
thanks for post result
BR,
BEHBOODI
Old 02-19-2013, 18:03   #15 (permalink)
daroas's Avatar
Member: 194078
hello, i'm have here one i9000 full dead... I'm use USB Jig and Download mode but no have sucess.. When the unit is plugged into the USB it was recognized that managed to install a drive with the device name now SMDK SOC SEC Board. But in a split second disconnects ..
What would be the possible solution to this problem?
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.49305 seconds with 11 queries
