10-23-2013, 09:45 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: earth
Member: 538815 Status: Offline Thanks Meter: 161 | Samsung Tab p1000 dead after jtag. try to repair in deadboot but now dead.. try to erase 2x then flash full dump from support and boot bin but still dead.. [QUOTE] Connecting box... Error 1 no box found, system isn't on-line. Connecting box... Version: V3.0 SN: GPGIRAN0000201 Port: COM12 Please press Power On key before any Read/Write/Erase operation. PIN1 = VCC PIN2 = TRST PIN3 = TDI PIN4 = TMS PIN5 = TCK PIN7 = TDO PIN8 = SYSRST Setting definition... Set definition done! Setting definition... Set definition done! Erase operation(Make sure to press Power on key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Erase succeed! Bad-block address: 0x0E9C0000( 233ΥΧ) [DB] Time: 42 s ========================================== Erase operation(Make sure to press Power on key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Erase succeed! Bad-block address: 0x0E9C0000( 233ΥΧ) [DB] Time: 42 s ========================================== Writing in progress(make sure to press Power On key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Error 11 phone doesn't respond for a long time,please reconnect! Time: 48 s ========================================== Writing in progress(make sure to press Power On key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Write succeed! Time: 31 s ========================================== Writing in progress(make sure to press Power On key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Write succeed! Time: 55:57 ========================================== Writing in progress(make sure to press Power On key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Write succeed! Time: 1:1 ========================================== Erase operation(Make sure to press Power on key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Erase succeed! Bad-block address: 0x00000000( 0ΥΧ) [CF] Bad-block address: 0x00040000( 0ΥΧ) [CF] Bad-block address: 0x00080000( 0ΥΧ) [CF] Bad-block address: 0x000C0000( 0ΥΧ) [CF] Bad-block address: 0x00100000( 1ΥΧ) [CF] Last edited by jatchaminda; 10-23-2013 at 14:52. |
10-23-2013, 11:52 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | procedure: *sold pinouts *set pinouts *auto full flash *full erase 2X *write fulldump *write bootfile *your imei is 00499.. means EFS is good, need to repair imei *repair imei in z3x samsung box in version 11.8 (tested version) |
10-23-2013, 14:05 | #4 (permalink) | |
Member: 538815 Status: Offline Thanks Meter: 161 | Quote:
but still dead.. before phone is power on then hang always. | |
10-23-2013, 14:24 | #5 (permalink) |
Member: 538815 Status: Offline Thanks Meter: 161 | iv got this error after full erase.. [QUOTE] Erase operation(Make sure to press Power on key)... CPU ID: 7704A01B. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Erase succeed! Bad-block address: 0x00000000( 0ΥΧ) [CF] Bad-block address: 0x00040000( 0ΥΧ) [CF] Bad-block address: 0x00080000( 0ΥΧ) [CF] Bad-block address: 0x000C0000( 0ΥΧ) [CF] Bad-block address: 0x00100000( 1ΥΧ) [CF] and so on.... [QUOTE] Last edited by jatchaminda; 10-23-2013 at 14:51. |
10-23-2013, 14:50 | #6 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | http://forum.gsmhosting.com/vbb/f705...olved-1674377/ Quote:
here is the m180s dump http://www.gpgdragonsupport.com/ftpp...0S_Full_1G.zip this is bootfile for m180s http://www.gpgdragonsupport.com/ftpp...M180S_Boot.bin | |
10-23-2013, 18:15 | #7 (permalink) | |
10-25-2013, 17:36 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: nigeria
Member: 581848 Status: Offline Thanks Meter: 119 | bros i personaly has this problem earlier for weeks till i did above process jatchimida and since then till now i ve done more than 30 p1000 and m180 without any problem it works like magic...if you had done all this and it didnt work thats to say your phone is hardware problem cos all the jtag is for is to repair boot so u can flash your phone so if ur phone can boot and can enter flash mode i think jtag work has finish....i advice you to check hardware |
The Following User Says Thank You to ramsey1976 For This Useful Post: |
