11-29-2011, 12:31 | #1 (permalink) |
Product Supporter Join Date: Jun 2008 Location: TURBHE JANTA MARKETNAVI MUMBAI Age: 45
Member: 787829 Status: Offline Sonork: 100.1615114 Thanks Meter: 917 | CPU: SC6600L7 Flash: NOR_EN71GL064 DA_LIB_VER_3.7.0.4 It is sensing the pinout fast... D-=18 D+=15 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM15 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_EN71GL064 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00000000, Size=0x00760000, Running NV=0x00007A00 Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. AVATOR TEAM PLS TELL ME HOW TO SOLVE THIS PROBLEM URGENTLY |
11-29-2011, 13:06 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
Solution: 1. Try to do "Reset", it should help you 2. If reset not helps then try to format mnaually with the address which is displayed in "read info", Means use the fat address shown in the read info of the handset to format it manually. (make sure to take full handset backup before you try this). 3. Even if this not helps, then only way to fix this is by flashing handset with correct flash file, if u dont have a flash file then u need to arrange a similar handset, read the flash from it and then flash it to your faulty handset. Br AvatorBox Team | |
Looking for a 5510 flash: where? | mitchbuchanan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-17-2004 08:12 |
A35-v20 Type FLASH: HC=A220 "LCD blank" ??? | pik2020 | x1x to x45/x50 | 5 | 02-20-2003 00:12 |
BE5 with 2M flash: how to upload russian menu? | chris_ua | Alcatel & TCL Old Models | 1 | 01-12-2003 19:04 |
3210 flash: How to backup? | cool | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-20-2001 19:16 |
A1018 After Flash: ERROR03 with ATR 5.3 | cala | Old Ericsson Phones & Sony Phones | 0 | 08-16-2001 10:35 |
