Need Spice M-5460 flash file Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=20 TXD=24 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: SPICE_M-5460_IND_VER12.0 thanxx in advance sir |
need spice m5460 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=20 TXD=24 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: SPICE_M-5460_IND_VER18.0 |
very very thanks sanjeevji my handset on ! |
>>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT6250 Hardware Version:8B00 Software Version:CA05 >>> Downloading First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00800000 -> 8M Flash ID:0x00C8006000170000 Flash Name:SF_GD25LQ64 ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 Formatting Start Adress(Hex): 0x00758000 Size(Hex): 0x000A8000 >>> Formatting... All Done... |
m-5460 phone sequirety locked how to unlock phone lock |
all spice flash file Welcome to the ./downloads/Spice/ folder of the support area for your service center |
spice M-5460 phone lock Simple use volcano box select cpu type 625A check on usb press run press back key and insert usb cable Here is the solution Analysis of USB port,Please insert phone USB cable. Connecting... Hardware version:CA05 Software version:0101 CPU TYPE:6252 Internal version:8B00 Boot downloading complete! Flash ID: 00C2002500370000 Flash Type: SF_MX25U6435E Chip Capacity: 0x800000(8MB) Mobile phone software version for:SPICE_M-5460_IND_VER18.0 Baud adjust...complete. Analysis of USB port,Please insert phone USB cable. Connecting... Hardware version:CA05 Software version:0101 CPU TYPE:6252 Internal version:8B00 Boot downloading complete! Flash ID: 00C2002500370000 Flash Type: SF_MX25U6435E Chip Capacity: 0x800000(8MB) Mobile phone software version for:SPICE_M-5460_IND_VER18.0 Baud adjust...complete. Format range: Start Address: 0x758000,Format Length :0x0A8000 >>Flash erasing complete! |
