Miracle Box GSMCampus |
01-01-2015, 09:10 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | all spd6531 imei repair final solution problem was sim registration failed. i tried to change imei via boot key and usb cable. but it failed to enter test mode.and imei change failed also. then i put sim. it said registration failed.and therefore com port drivers could not installed. becoz it gave error on mobile screen that sim is locked or not exist.(because this function require proper network access) then i tried with test sim inside.it said emergency calls.but com port driver installed in normal mode. and that`s all imei change done in a signle click by great miracle box. |
01-03-2015, 06:11 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | hello follow this intruction 1st select boot -9 and right check on Andriod/6531 then write imei and post result with screen shot or log |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
01-08-2015, 09:03 | #4 (permalink) |
Member: 237155 Status: Offline Thanks Meter: 415 | info log. ------------------------- Scanning USB Serial port... SU2Serial Port: COM169 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot9... CPU type: 6531A Flash type: NOR Flash ID: 002C00CB(00180000) Flash Model: MX25l128 Flash Size: 0x1000000(16.0M) Being analyzed,Wait... IMEI1 :352273017386340 IMEI2 :352751019523267 IMEI3 :358570010103893 IMEI4 :910575601400468 Unlock Code: 1234 Privacy Code: 1234 ------------------------------- imei change log ------------------------------ Definition Applied Scanning USB Serial port... SU2Serial Port: COM200 ReImei,wait... Previous IMEI inf: IMEI1 :352273017386340 IMEI2 :352751019523267 IMEI3 :358570010103893 IMEI4 :910575601400468 ReImei Completed. ------------------------ i want to tell for more explain that i have used power on method instead of boot method.and therefore must tick power on option in miracle software. |
