Miracle Box GSMCampus |
02-09-2016, 23:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Age: 72
Member: 18362 Status: Offline Thanks Meter: 6 | boot mt6572 damaged after flash (Replied & Closed) Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MTK USB Port (COM24) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... >>BootData ERR(2): 0_0 Last edited by [SV]; 02-11-2016 at 10:11. Reason: (Replied & Closed) |
02-11-2016, 05:40 | #6 (permalink) | |
No Life Poster Join Date: Dec 2015
Member: 2502231 Status: Offline Thanks Meter: 351 | Quote:
flashing with wrong flash file also corrupt or erase preloader which result to the error you are facing. pls try to flash with this file smg900fglxys5mt6572fullbckp.part2 - Download - 4shared - s4tri0.blgspt arif | |
The Following User Says Thank You to gsmrockers123 For This Useful Post: |
02-11-2016, 08:34 | #7 (permalink) |
Member: 18362 Status: Offline Thanks Meter: 6 | Thank you in advance for your answer gsmrockers123 I shall inform you after the flash. As for you swapan I have use the last official version 2.27 not cracker thank you anyway |
