Miracle Box GSMCampus |
05-17-2015, 18:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: MIRACLE TEAM
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | ERROR RDN60, RDN61, RDN62 (Mismatch)Reason & Solution MIRACLE BOX & EAGLE EYE ERROR RDN60, RDN61, RDN62 Reason & Solution Last edited by [SV]; 11-03-2017 at 00:57. |
The Following 7 Users Say Thank You to [SV] For This Useful Post: |
05-17-2015, 18:27 | #2 (permalink) |
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Error rdn 60 ERROR ID RDN60 : FIRST TIME YOU USE MIRACLE BOX/MIRACLE EAGLE EYE YOU NEED TO UPDATE DONGLE NOTE : 1 DONGLE WORK WITH 1 BOX IF YOU USE 1 DONGLE with 2 BOX then DONGLE CORRUPTED & WE NO HAVE ANY SOLUTION. YOU NEED TO BUY NEW DONGLE. |
05-17-2015, 18:29 | #3 (permalink) |
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Error rdn62 error firmware update error Solution Repair Firmware & Update Firmware |
The Following 9 Users Say Thank You to [SV] For This Useful Post: |
05-17-2015, 18:32 | #4 (permalink) |
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Error id rnd61 dongle & box mismatch ERROR ID RND61 DONGLE & BOX MISMATCH : This Dongle you already update with other box so you need to Use Same Dongle with Same Box Can't Use 1 Dongle with 2 Box This Error Come when you use 1 Dongle with Other Box NOTE : 1 DONGLE WORK WITH 1 BOX IF YOU USE 1 DONGLE with 2 BOX then DONGLE CORRUPTED & WE NO HAVE ANY SOLUTION. YOU NEED TO BUY NEW DONGLE. Last edited by [SV]; 02-01-2019 at 07:49. |
The Following 17 Users Say Thank You to [SV] For This Useful Post: |
08-28-2018, 11:37 | #5 (permalink) |
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Miracle Firmware Mismatched Solution Miracle Firmware Mismatched Solution |
The Following 4 Users Say Thank You to [SV] For This Useful Post: |
07-23-2019, 16:24 | #6 (permalink) |
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | System Change Setting System Change Setting Error If you Change System Date then this error come Solution we no have this for security Just wait for Other Update Before Install new Update Must Delete old |
The Following 6 Users Say Thank You to [SV] For This Useful Post: |
