Miracle Box GSMCampus |
03-20-2016, 14:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | First in the world Samsung SM-G5500 Android_5.1_MT6580_Read Scatter Flash Done with Miracle Box +Miracle Key Samsung On5 SM-G5500 MT6580 Version:5.1 Read Factory scatter file Done Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM37) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x00EC000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000+0x20000000 Reading infr(EMMC)... id:LMY47I test-keys version:5.1 model:tx6580_weg_xz_l brand:alps manufacturer:alps PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 SECCFG BaseAddr:0x1C80000 Size:0x40000 LK BaseAddr:0x1CC0000 Size:0x60000 BOOT BaseAddr:0x1D20000 Size:0x1000000 RECOVERY BaseAddr:0x2D20000 Size:0x1000000 PARA BaseAddr:0x3D20000 Size:0x80000 LOGO BaseAddr:0x3DA0000 Size:0x800000 EXPDB BaseAddr:0x45A0000 Size:0xA00000 FRP BaseAddr:0x4FA0000 Size:0x100000 NVDATA BaseAddr:0x50A0000 Size:0x2000000 METADATA BaseAddr:0x70A0000 Size:0x2760000 OEMKEYSTORE BaseAddr:0x9800000 Size:0x200000 SECRO BaseAddr:0x9A00000 Size:0x600000 KEYSTORE BaseAddr:0xA000000 Size:0x800000 SYSTEM BaseAddr:0xA800000 Size:0x60000000 CACHE BaseAddr:0x6A800000 Size:0x10000000 USERDATA BaseAddr:0x7A800000 Size:0x60000000 INTSD BaseAddr:0xDA800000 Size:0x10780000 FLASHINFO BaseAddr:0xEAF80000 Size:0x1000000 Done. Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM37) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x00EC000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000+0x20000000 Reading preloader... Reading lk... Reading boot... Reading recovery... Reading logo... Reading frp... Reading secro... Reading system... Reading cache... Reading userdata... Saving as scatter file... >>Done! |
