Miracle Box GSMCampus |
02-07-2017, 16:28 | #331 (permalink) |
Junior Member Join Date: Mar 2015 Location: Bangladesh Age: 28
Member: 2363336 Status: Offline Sonork: gsmmunna Thanks Meter: 5 | Huawei Y336-u02 Firmware Need 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Please Hold BootKey(UP and DOWN),Insert USB cable 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Scanning USB Serial port... SU2Serial Port: COM73 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot19... BootLoad Error. ID: 1 Definition Applied Connecting to Phone,Wait..ok Hardware:sc8830 Board:y336-u02 CPU ABI:armeabi-v7a Manufacturer:huawei Model:huawei y336-u02 Android Ver:4.4.2 bootloader ver:unknown USB config:mtp,adb User:jenkins Baseband ver:tm_base_mp_ii_huawei_w15.34|sc7731g_cp0_modem| 08-31-2015 17:58:18 Build number:y336-u02v100r001c567b113 ID:huaweiy336-u02 Region:us Language:en Chipset:sc8830 Root: Not Root >>Done |
02-08-2017, 02:34 | #333 (permalink) |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | REQUEST ALWAYS HERE : ஜ۩۞۩ஜ Flash File Req Here Only (Post Screenshot With File Request) ஜ۩۞۩ஜ ========================= BR. SWAPAN |
02-08-2017, 05:22 | #335 (permalink) | |
No Life Poster Join Date: Dec 2015
Member: 2502231 Status: Offline Thanks Meter: 351 | Quote:
check here next time post Miracle Gui with visible serial number | |
02-08-2017, 16:06 | #336 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 681090 Status: Offline Sonork: 100.1621067 Thanks Meter: 120 | want to firmware for htc d828d her is log Welcome to use Miracle Box (World's First Fuzzy Logic Based Tool) Update:16-12-05 Firmware Version:1.16 Connected OK. Fuzzy Logic Method is very safe and reliable ! License Expire Date: 2017-11-05 Check Authentication... You use Latest Miracle Software ______________________________ Miracle Box Version 2.42 Release: 21st Janurary 2017 ______________________________ www.support.amiraclebox.com Buy 1 year Support Activation BIG BIG UPDATES ON THE WAY Br. [SV] Miracle Team __________[FACEBOOK]__________ http://facebook.com/amiracleteam ___________SUPPORT]___________ Miracle Team - GSM-Forum ______________________________ Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM61) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6753 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x03A3E00000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x80000000 Reading infr(EMMC)... model:HTC Desire 828 dual sim id:LMY47D release-keys version:5.1 model:htc_a51bml_dwl brand:htc manufacturer:HTC PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 PERSIST BaseAddr:0x1C80000 Size:0x3000000 KB BaseAddr:0x4C80000 Size:0x100000 DKB BaseAddr:0x4D80000 Size:0x100000 SECCFG BaseAddr:0x4E80000 Size:0x40000 PG1FS BaseAddr:0x4EC0000 Size:0x400000 RESERVE1 BaseAddr:0x52C0000 Size:0xD40000 PG2FS BaseAddr:0x6000000 Size:0x1000000 LK BaseAddr:0x7000000 Size:0x100000 SECRO BaseAddr:0x7100000 Size:0x600000 PARA BaseAddr:0x7700000 Size:0x80000 LOGO BaseAddr:0x7780000 Size:0x800000 FRP BaseAddr:0x7F80000 Size:0x80000 HOSD BaseAddr:0x8000000 Size:0x2000000 HTCSEC BaseAddr:0xA000000 Size:0x100000 TOOL_DIAG BaseAddr:0xA100000 Size:0xA00000 RESERVE2 BaseAddr:0xAB00000 Size:0x1500000 FATALDEVLOG BaseAddr:0xC000000 Size:0x1400000 DEVLOG BaseAddr:0xD400000 Size:0x1400000 EXPDB BaseAddr:0xE800000 Size:0xA00000 TEE1 BaseAddr:0xF200000 Size:0x500000 TEE2 BaseAddr:0xF700000 Size:0x500000 METADATA BaseAddr:0xFC00000 Size:0x2000000 LKBACKUP BaseAddr:0x11C00000 Size:0x100000 OTAFW BaseAddr:0x11D00000 Size:0x4000000 SENSOR_HUB BaseAddr:0x15D00000 Size:0x80000 CIR_IMG BaseAddr:0x15D80000 Size:0x8000 CARRIER BaseAddr:0x15D88000 Size:0x1400000 CONTROL BaseAddr:0x17188000 Size:0x8000 BATTERY BaseAddr:0x17190000 Size:0xA00000 APPPRELOAD BaseAddr:0x17B90000 Size:0x12200000 COTA BaseAddr:0x29D90000 Size:0x3C00000 EXTRA BaseAddr:0x2D990000 Size:0x10000 ANDINFO BaseAddr:0x2D9A0000 Size:0x8000 OEMKEYSTORE BaseAddr:0x2D9A8000 Size:0x200000 KEYSTORE BaseAddr:0x2DBA8000 Size:0x800000 NVDATA BaseAddr:0x2E3A8000 Size:0x2000000 RESERVE BaseAddr:0x303A8000 Size:0x1C58000 CACHE BaseAddr:0x32000000 Size:0x10000000 BOOT BaseAddr:0x42000000 Size:0x2000000 RECOVERY BaseAddr:0x44000000 Size:0x2000000 SYSTEM BaseAddr:0x46000000 Size:0xD0000000 USERDATA BaseAddr:0x116000000 Size:0x288000000 FLASHINFO BaseAddr:0x39E000000 Size:0x1000000 >>Done. |
02-08-2017, 16:11 | #337 (permalink) |
Member: 681090 Status: Offline Sonork: 100.1621067 Thanks Meter: 120 | need htc d828d firmware d828d firmware need Welcome to use Miracle Box (World's First Fuzzy Logic Based Tool) Update:16-12-05 Firmware Version:1.16 Connected OK. Fuzzy Logic Method is very safe and reliable ! License Expire Date: 2017-11-05 Check Authentication... You use Latest Miracle Software ______________________________ Miracle Box Version 2.42 Release: 21st Janurary 2017 ______________________________ www.support.amiraclebox.com Buy 1 year Support Activation BIG BIG UPDATES ON THE WAY Br. [SV] Miracle Team __________[FACEBOOK]__________ http://facebook.com/amiracleteam ___________SUPPORT]___________ Miracle Team - GSM-Forum ______________________________ Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM61) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6753 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x03A3E00000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x80000000 Reading infr(EMMC)... model:HTC Desire 828 dual sim id:LMY47D release-keys version:5.1 model:htc_a51bml_dwl brand:htc manufacturer:HTC PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 PERSIST BaseAddr:0x1C80000 Size:0x3000000 KB BaseAddr:0x4C80000 Size:0x100000 DKB BaseAddr:0x4D80000 Size:0x100000 SECCFG BaseAddr:0x4E80000 Size:0x40000 PG1FS BaseAddr:0x4EC0000 Size:0x400000 RESERVE1 BaseAddr:0x52C0000 Size:0xD40000 PG2FS BaseAddr:0x6000000 Size:0x1000000 LK BaseAddr:0x7000000 Size:0x100000 SECRO BaseAddr:0x7100000 Size:0x600000 PARA BaseAddr:0x7700000 Size:0x80000 LOGO BaseAddr:0x7780000 Size:0x800000 FRP BaseAddr:0x7F80000 Size:0x80000 HOSD BaseAddr:0x8000000 Size:0x2000000 HTCSEC BaseAddr:0xA000000 Size:0x100000 TOOL_DIAG BaseAddr:0xA100000 Size:0xA00000 RESERVE2 BaseAddr:0xAB00000 Size:0x1500000 FATALDEVLOG BaseAddr:0xC000000 Size:0x1400000 DEVLOG BaseAddr:0xD400000 Size:0x1400000 EXPDB BaseAddr:0xE800000 Size:0xA00000 TEE1 BaseAddr:0xF200000 Size:0x500000 TEE2 BaseAddr:0xF700000 Size:0x500000 METADATA BaseAddr:0xFC00000 Size:0x2000000 LKBACKUP BaseAddr:0x11C00000 Size:0x100000 OTAFW BaseAddr:0x11D00000 Size:0x4000000 SENSOR_HUB BaseAddr:0x15D00000 Size:0x80000 CIR_IMG BaseAddr:0x15D80000 Size:0x8000 CARRIER BaseAddr:0x15D88000 Size:0x1400000 CONTROL BaseAddr:0x17188000 Size:0x8000 BATTERY BaseAddr:0x17190000 Size:0xA00000 APPPRELOAD BaseAddr:0x17B90000 Size:0x12200000 COTA BaseAddr:0x29D90000 Size:0x3C00000 EXTRA BaseAddr:0x2D990000 Size:0x10000 ANDINFO BaseAddr:0x2D9A0000 Size:0x8000 OEMKEYSTORE BaseAddr:0x2D9A8000 Size:0x200000 KEYSTORE BaseAddr:0x2DBA8000 Size:0x800000 NVDATA BaseAddr:0x2E3A8000 Size:0x2000000 RESERVE BaseAddr:0x303A8000 Size:0x1C58000 CACHE BaseAddr:0x32000000 Size:0x10000000 BOOT BaseAddr:0x42000000 Size:0x2000000 RECOVERY BaseAddr:0x44000000 Size:0x2000000 SYSTEM BaseAddr:0x46000000 Size:0xD0000000 USERDATA BaseAddr:0x116000000 Size:0x288000000 FLASHINFO BaseAddr:0x39E000000 Size:0x1000000 >>Done. |
02-19-2017, 18:27 | #340 (permalink) | |
Freak Poster Join Date: Jul 2016 Location: Lahore
Member: 2595115 Status: Offline Thanks Meter: 54 | Dear Friend! Need me Qmobile L4 Flash FIle.... Brand:-Qmobile Model:- L4 CPU:- MT6261 Info:- Quote:
02-19-2017, 18:49 | #341 (permalink) | |
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Quote:
Qmobile L4 Flash File MT_6261 NEXT TIME POST MIRACLE IMAGE ========================= BR. SWAPAN | |
The Following User Says Thank You to swapan For This Useful Post: |
02-23-2017, 07:00 | #343 (permalink) |
Freak Poster Join Date: Oct 2015 Location: bogra
Member: 2468982 Status: Offline Sonork: Koler.gaan Thanks Meter: 72 | Hi I can not See FRP Rest File On miracle Download Where I Can Find IT ? If You Want See = Miracle Box->About->Download-> Na thing Show Why ? |
02-26-2017, 07:11 | #344 (permalink) |
Member: 2502231 Status: Offline Thanks Meter: 351 | |
02-28-2017, 11:01 | #345 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Please Hold BootKey(UP and DOWN),Insert USB cable 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Scanning USB Serial port... SU2Serial Port: COM4 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot19... BootLoad Error. ID: 1 Definition Applied Starting... Searching for devices fastboot... [ERROR]: No devices fastboot Make sure Smartphone in fastboot mode.! Definition Applied Starting... Searching for devices fastboot... [ERROR]: No devices fastboot Make sure Smartphone in fastboot mode.! Definition Applied Starting... Searching for devices fastboot... [ERROR]: No devices fastboot Make sure Smartphone in fastboot mode.! Definition Applied Connecting to Phone,Wait..ok Hardware:sc8830 Board:y336-u02 CPU ABI:armeabi-v7a Manufacturer:huawei Model:huawei y336-u02 Android Ver:4.4.2 bootloader ver:unknown USB config:mtp,adb User:kitkat Build number:y336-u02v100r001c328b106 ID:huaweiy336-u02 Region:us Language:en Chipset:sc8830 Root: Not Root Done |
