Miracle Box GSMCampus |
08-23-2017, 15:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | help mtk8163 not supported Welcome to use Miracle Box (World's First Fuzzy Logic Based Tool) Update:17-06-22 Firmware Version:1.16 Connected OK. Fuzzy Logic Method is very safe and reliable ! License Expire Date: 2018-03-15 Check Authentication... You use Latest Miracle Software ______________________________ Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek USB Port (COM57) Please Hold "ON" to connect with the phone... Not Supported Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek USB Port (COM57) Please Hold "ON" to connect with the phone... Not Supported Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek USB Port (COM57) Please Hold "ON" to connect with the phone... >>Not Supported |
The Following User Says Thank You to simpleprince49 For This Useful Post: |
