Miracle Box GSMCampus |
05-01-2017, 05:52 | #1 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Pakistan Panjab in Dahranwala
Member: 2441094 Status: Offline Thanks Meter: 69 | How to flash qualcomm via miracle box. and sulotion thsnks mirale box team. |
05-01-2017, 07:18 | #2 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: INDIA>GUJARAT
Member: 1497850 Status: Offline Sonork: 100.1601368 QQID:21952428 Thanks Meter: 1,575 | Quote:
we not support any firmware u can use google for find ur firmware thne goto qcom tab flashing select one by one model pres both volume key and insert cable (its caled edl) scan port select 9008 com port select firehorse programmer search path raw program patch file click edl mode press start for flashing miracle team idrish911 | |
The Following User Says Thank You to idrish911 For This Useful Post: |
06-02-2017, 06:12 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Emmc & Ufs Chips Age: 42
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | as mentioned download redmi3s file (use google) extract file with 7zip go to qcom tab go flashing put set in EDL mode use edl cable for this select comport of set select programmer from extracted image folder select path select raw program select patch 0 select edl mode press start wait to finish operation after success ur issue solved http://forum.gsmhosting.com/vbb/f715...017-a-2227228/ br closed Last edited by king.of.gsm; 06-02-2017 at 13:13. |
