Miracle Box GSMCampus |
12-11-2016, 09:03 | #2 (permalink) |
No Life Poster Join Date: May 2012 Age: 27
Member: 1764566 Status: Offline Sonork: SUSPENDED Thanks Meter: 5,763 | Can't Get Your Model samsung j7 ( sm-j500h ) Clear First WHich Model You Have nd Also Plz Try With Miracle Box if You r Facing Problem Kindly Post SS Of Miracle Box |
12-11-2016, 09:06 | #3 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | try this method without any box 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up 14.click on massege then write Google in sms |
