Miracle Box GSMCampus |
04-10-2013, 07:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Bharat > Jalandhar
Member: 566335 Status: Offline Thanks Meter: 160 | MTK 625A IMEI Writing PROBLEM EVen i have changed my pc , still same problem |
The Following User Says Thank You to ..::ARUN::.. For This Useful Post: |
04-10-2013, 07:58 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | first format then repair imei it work definately |
04-10-2013, 08:18 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | 1ST FILL TAC AND FAC DIGIT THEN TRY IF NOT SOLVED THEN TRY IMEI SWITCH ON AND MANY TIME IN USB MODE SET NOT TURN ON TEST MODE THEN NEED CONECT SET IN MANUALY RX TX IN COM MODE DO ALL IF SAME PROBLEM THEN NEED TO CONTACT ME OR ANY SUPPORTER [email protected] |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
04-10-2013, 08:38 | #4 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | |
10-15-2014, 05:45 | #6 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | imei first 6digit is tac and 7&8 digit is fac select imei switch off find pin out or conect with usb cable then press start note-if imei repair option is disable then press CTRL+M for enable this option |
10-17-2014, 05:00 | #11 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | for show imei option nedd press CTRL+M after show imei option go imei switch off fill imei now conect your set with jigs or usb cable then press start very siple for repair imei |
