Miracle Box GSMCampus |
04-14-2013, 05:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | micromax x222 succes only usb Waiting for USB Port... Set port to COM35 Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CE00 SW:0101 Test Mode, Reading Information From the Phone... UnLock Code: 0000 R IMEI1 OK: 91122645009237-3 R IMEI2 OK: 91122645054737-6 NONE IMEI3 >>NONE IMEI4 2nd read flsh Set port to COM35 Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CE00 md:8B00 Downloading Boot7 ... Nor Flash Type: [MX] MX25U6435E Nor Flash Code: 00C20025(00370000) Nor Flash Size: 0x800000 Hex Bytes Reading(Nor)... The phone information: TINNO52_10A_GEMINI64_PCB01_GPRS_MT6252_S01.E910_MP _F1_20.BIN_FLNMX25U6435E the file not be encrypted Read OK. Total time: 0 mins 22 s >>File Save to: F:\CHINA FLASH FILE\micromax\x222\TINNO52_10A_GEMINI64_PCB01_GPRS _MT6252_S01.E910_MP_F1_20.BIN_FLNMX25U6435E 3rd format Definition Applied you can Set Formatting Addr Waiting for USB Port... Set port to COM35 Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CE00 md:8B00 Downloading Boot7 ... Nor Flash Type: [MX] MX25U6435E Nor Flash Code: 00C20025(00370000) Nor Flash Size: 0x800000 Hex Bytes Formatting Nor Flash... Format Start Addr: 0x740000, Size: 0xC0000 >>Formatted OK. boot key press home button then insert usb cable Last edited by shamsulhaq; 04-14-2013 at 06:07. |
04-14-2013, 06:13 | #2 (permalink) |
Member: 1847344 Status: Offline Thanks Meter: 300 | imei change Please Turn on your phone by battery before pressing START Waiting for USB Port... if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Abort by User none usbport, maybe driver not installed Waiting for USB Port... Set port to COM35 Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CE00 SW:0101 Test Mode, Reading Information From the Phone... W IMEI1 OK: 91122645009237-3 W IMEI2 OK: 91122645054737-6 NONE IMEI3 all done only usb cable a great team miracle box |
04-14-2013, 09:32 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | good job bro keep it up post more successful story in right section http://forum.gsmhosting.com/vbb/f715...e-box-1404962/ |
