Miracle Box GSMCampus |
08-26-2016, 17:48 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2615667 Status: Offline Thanks Meter: 3 | miracle box beginers guide please help a brother here 1) are my system specs compatible? 2) do i install 2.36 or 2.35a software 3) what comes first in installation, drivers or software? 4)does the order of comports matter? 5)what is miracle boot key? 6)when inserting an android phone, do u press volume down or volume up? 7) keypad phone, do u press power or *# 8)apart from drivers on amiracle , are there any additional drivers? 9)is internet connectivity required during program booting or during flashing also? 10) can rj45 cable b used for android phones or keypad phones? 11) in above, do u tick usb mode or pinouts? 12)when software indicates waiting for usb, what is the most likely check issue? 13) any settings done on the pin outs area? 14) any other thing you think i shld know thanks you |
The Following User Says Thank You to mureithindwiga For This Useful Post: |
08-27-2016, 08:12 | #4 (permalink) | |
No Life Poster Join Date: May 2012 Age: 27
Member: 1764566 Status: Offline Sonork: SUSPENDED Thanks Meter: 5,763 | Quote:
1 yes You Can run Your Box On This Mahine 2 Install Latest Ver ie. 2.37 3 First It Says To Un-Install old Setup from PC 4 Try To Use Comport In Below Number 5 Miracle Boot Is Key Used Specially For Phones WHich Need to Press Boot Key For Connect if You Use Boot Key No Need To Press Boot Key 6 Mostly Mediatek Android No Need Press Boot Key For Spd Phones Need To Press Boot Key May Volume Keys 7 It Decide Your Phone need To Press Boot Key Or Not 8 If You Are Using Fresh PC You Need To Install That Driver For Connect Phones nd Box 9 Yes Internet Need For Run Your box 10 Rj 45 RX tX U Can Use For Feature Phones 11 Connect USB If Phone Not Connect Check Port or USB jack 12 No Need Extra Settings 13 [X] Thanx | |
The Following 2 Users Say Thank You to IMRAN_ANSARI For This Useful Post: |
