Miracle Box GSMCampus |
06-13-2019, 10:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2014 Location: Technology town
Member: 2252481 Status: Offline Sonork: 1660352 Thanks Meter: 206 | miracle box not opening no peep sound (Replied & Closed) Last edited by [SV]; 06-15-2019 at 09:57. Reason: (Replied & Closed) |
The Following User Says Thank You to Techsky For This Useful Post: |
06-13-2019, 15:52 | #6 (permalink) |
Junior Member Join Date: Jul 2015 Location: Desert
Member: 2420741 Status: Offline Sonork: 100.1668113 Thanks Meter: 7 | Same problem here bro. When i run Miracle thunder, i get the error "Server Connection Error Check Intenet!" Yet my connection to the internet is OK. This started two days ago. Also i note that the Miracle box server is not online. Any solution please? |
The Following User Says Thank You to wnthiani For This Useful Post: |
06-13-2019, 16:49 | #9 (permalink) |
Member: 2420741 Status: Offline Sonork: 100.1668113 Thanks Meter: 7 | I wish i had skype.. I have tried a free vpn and surprisingly the miracle server site was online! Now the problem is how to make Miracle box .exe to use the vpn interface. Thanks friend for the tip anyway.. |
06-14-2019, 06:09 | #10 (permalink) |
No Life Poster Join Date: Nov 2011 Location: MIRACLE TEAM
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | No Need any VPn for Miracle write here info Miracle Sn Which Version u r using from which country you are from |
The Following User Says Thank You to [SV] For This Useful Post: |
06-14-2019, 06:30 | #12 (permalink) |
Member: 2420741 Status: Offline Sonork: 100.1668113 Thanks Meter: 7 | Bro SV, thanks for the response.. but how can we get the Serial number if the box cannot even open up? There is no serial number at the box package, and there is no serial number at the miracle key dongle. Also please note that the Miracle server is not accessible from Kenya, this is somewhere in Africa. Kindly assist... |
06-14-2019, 09:20 | #15 (permalink) |
Member: 2420741 Status: Offline Sonork: 100.1668113 Thanks Meter: 7 | [QUOTE='[SV];13693636']No Need any VPn for Miracle write here info Miracle Sn : MBCM170819NC0714 Which Version u r using : Miracle Box from which country you are from: Kenya |
