Old 11-28-2019, 05:49   #4051 (permalink)
Member: 1858274
Buen dia estoy tratando de activar el modulo de miracle xiaomi en mi box MBCM190315NC321C pero indican que no existe el serial en su servidor necesito resolver este tema ya que la box esta completamente activada y funcionando incluso con varios pack activos por favor indiquenme una solucion gracias
les adjunto el mensaje arrojado en XpertsGsm
Job Data:
SerialNumber : MBCM190315NC321C
Quantity : 1
Result :
MBCM190315NC321C: SerialNumber not Exist in system,Contact admin,Aborted.
Old 11-28-2019, 16:32   #4052 (permalink)
Member: 1858274
Good morning I am trying to activate the miracle xiaomi module in my MBCM190315NC321C box but they indicate that the serial does not exist on your server I need to resolve this issue since the box is fully activated and working even with several active pack please indicate me a solution thanks
I attach the message thrown in XpertsGsm
Job Data:
Quantity : 1
Result :
Old 11-28-2019, 16:37   #4053 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Thanks Meter: 35,116
Reply to User
Job Data:
Quantity : 1
Result :
All Activation need Miracle Key serial Number not Box
MICBX19A00022955
Old 11-28-2019, 20:20   #4054 (permalink)
misal's Avatar
Member: 185854
Sonork: 100.1592083
Thanks Meter: 285
New miracal box not actived
Box SN: MBCM190829NC3679 Added
PLS sir actived my box..pls
Old 11-28-2019, 22:15   #4055 (permalink)
Member: 1858274
Good friend me again in the same way with the miracle key serial rejects it should be a problem in the miracle database if you can check I would appreciate it
Job Data:
SerialNumber : MICBX19A00022955
Quantity : 1
Result :
MICBX19A00022955: SerialNumber not Exist in system,Contact admin,Aborted.
Old 11-28-2019, 23:10   #4056 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Job Data:
Quantity : 1
Result :
from our side all things ok
Username: Migonzv
Box Serial: MBCM190315NC321C
Dongle Serial: MICBX19A00022955
Old 11-29-2019, 06:24   #4057 (permalink)
Member: 1858274
Good I inform you that after you have checked the information of my box the activation of the xiaomi package was successful now when trying to access the module it no longer tells me that it is not activated but it tells me the following message "Box is not registered, Please Registered" please can you help me with this problem since it only happens with this xiaomi module the others are working perfectly.
I have tried the following but without success:
reinstall the xiaomi module
reinstall the miracle thunder module and try to register the box again but it indicates that it is already registered
repair firmware of the box I repair it but the xiaomi module keeps asking me to register
I don't know what else to do if you could help me with this last step I would appreciate it thanks
Miracle Box:
Username: Migonzv
Old 12-02-2019, 17:15   #4058 (permalink)
Member: 1858274
Good morning friends by favior if you can take care of the case I would appreciate it since we only need to solve the problem that the module of xiaomi pack indicates that the box is not registered when in fact if it is and the other pack work perfectly Thank you
Miracle Box:
Username: Migonzv
Old 12-02-2019, 22:18   #4059 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Reply to User
Miracle Box:
Username: Migonzv
download : https://www.alpemix.com/site/Alpemix.exe
Send Pm User id and password
Old 12-11-2019, 19:05   #4060 (permalink)
Member: 743934
Thanks Meter: 9
Thunder SN: MIRTDIDS54185156 i dont known if my dongle expire plss check advance thank u
Old 12-12-2019, 10:43   #4061 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Reply to User
License Active Date: 2018-12-08
License Expire Date: 2019-12-08
Licensed Expire
please Buy Miracle 1 Year Activation
Old 12-16-2019, 16:00   #4062 (permalink)
Member: 2915467
Sonork: No son
Miracle samsung unlock
When setup after installing not runing setup how to fix
Old 12-16-2019, 17:44   #4063 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Post Your Serial Number
Old 12-19-2019, 08:33   #4064 (permalink)
Member: 1937189
Sonork: ueekingm kinetic
Thumbs up Miracle Box Activation
Key serial number: MICBX17S00005682
Country: UGANDA
Box S/N: NULL, ID1002
Please Activate my Box
Pliz ADMIN, who is the Authorised dealer in Uganda?
Old 12-19-2019, 08:56   #4065 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Reply to User
Country: UGANDA
License Active Date: 2018-04-12
License Expire Date: 2019-04-12
you need to buy Miracle 1 Year Activation
Miracle Team Official Online Shop
www.miracleteam.shop
Page generated in 0.46784 seconds with 8 queries
