Miracle Box GSMCampus |
05-01-2014, 01:16 | #1 (permalink) | ||
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | MT6572 and MT6575 CAN'T FIX / REPAIR IMEI INVALID/NULL software logs says OK but nothings happen / still the same. Quote:
05-07-2014, 07:39 | #2 (permalink) | |
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | IMEI REPAIR STILL NOR FIX !!! software says OK/ done, but still imei invalid/null !!! Quote:
05-07-2014, 08:21 | #3 (permalink) |
No Life Poster Join Date: Jun 2011 Location: India Age: 37
Member: 1750704 Status: Offline Thanks Meter: 12,171 | DEAR BROTHER IF IMEI REPAIR IS OK THEN ITS NOT FAULT OF MIRACLE BOX FOR REPAIR INVALID IMEI MUST BE USED NETWRK UNLOK CODE OR WRITE NV FILE FOR FIX NETWORKS U ARE OLD USER OF MIRACLE BOX BUT U FORGET SOMETHING ALWAYs |
05-07-2014, 09:45 | #6 (permalink) |
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | i think Miracle supporters not understand what i posted here, i/ve tried to write/repair this kind of phone/chipset and software say OK/DONE , but when i check/dial *#06# imei null display in screen. Then i tried to flash also in other version of .pac file back-up.. still SAME RESULT when i repair IMEI... so it means, this TOOL CAN NOT REPAIR DAMAGE IMEI of MT6572 and MT6575 ?????????. |
05-07-2014, 12:39 | #7 (permalink) |
Member: 1750704 Status: Offline Thanks Meter: 12,171 | Send a message via Yahoo to bronce IMEI REPAIR STILL NOR FIX !!! software says OK/ done, but still imei invalid/null !!! Quote: Miracle Box 1.84 SUMMER HOT UPDATE 6th MAY 2014 ======[Download]====== http://*******/Umzo1C ======================= if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Waiting for USB Port... Set MediaTek PreLoader USB VCOM (Android) (COM15) Please Hold "ON" to connect with the phone... Waiting for USB Port... Set Connecting AT Mode Test Mode, Reading Information From the Phone... W IMEI1 OK: 35523603013164-4 R IMEI2 OK: 90595426201463-4 R IMEI3 OK: FFFFFFFFFFFFFF-15 R IMEI4 OK: FFFFFFFFFFFFFF-15 Please Hold "ON" to connect with the phone... Connecting to Phone,Wait.. Connecting to Phone,Wait..ok Hardware:mt6575 Board: CPU ABI:armeabi-v7a Manufacturer:MZ Model:GT-I8190 Android Ver:2.3.3 bootloader ver:unknown User:release-builder Baseband ver:MAUI.11AMD.W11.50.SP.V18.P2, 2012/10/10 18:37 Build number:JRO03H.I8190XXALJL IMEI1: 355236030131644 Root: Rooted CHECK UR LOGS WHT U ARE SAYING AND WHT U ARE WRITE U SAID IMEI NULL IF IMEI NULL WHY GAVE IMEI IN INFO IN ANDROID TAB WHICH U WRITE ??? PZ POST VIDEO |
05-08-2014, 05:12 | #8 (permalink) | |
Freak Poster Join Date: Oct 2009 Location: {INDIA * UAE}
Member: 1134306 Status: Offline Thanks Meter: 133 | Quote:
You are missing one thing 1st root the set after that change imei 100% success good luck | |
