Old 08-21-2014, 04:26   #1 (permalink)
Member: 706023
Sonork: 100.1647210
Thanks Meter: 75
My Miracle box shows not connected error
I installed ver 1.91 miracle box, but when I open Miracle's software, the following error shows up.
I created a Logs folder in the directory folder where Miracle software is installed.
when I open the software, the light of alarm of the box turns on.
I also tried different versions of software, but it didn't work.
Is there any solution for the problem?
Sent from my SPH-L720 using Tapatalk
Old 08-21-2014, 12:09   #2 (permalink)
Member: 1749678
Sonork: 1608318
Thanks Meter: 256
http://forum.gsmhosting.com/vbb/10490393-post49.html
Old 08-21-2014, 15:53   #3 (permalink)
Member: 706023
Sonork: 100.1647210
Thanks Meter: 75
The link you posted here is not related to my problem at all
Old 08-21-2014, 16:01   #4 (permalink)
Member: 706023
Sonork: 100.1647210
Thanks Meter: 75
Are there any supporters working here or not?
I have posted a problem yesterday, but haven't received any solutions from the supporters.
Is this how you provide us customer service?
Old 08-21-2014, 16:03   #5 (permalink)
Crazy Poster
Member: 1712008
Sonork: access111
Thanks Meter: 11
bro first of all uninstall the software,and delete the program file in registry and startup then disable antivirus and reinstall but don't connect box while installing it after then post result. if problem persists then we'll move to the next level
...................... ofaj links technology ............................
Old 08-21-2014, 17:14   #6 (permalink)
Member: 706023
Sonork: 100.1647210
Thanks Meter: 75
Thanks for the replay
I have already done all steps. I even installed the software in a new computer, but I am still receiving the same error.
Would you please post the other levels?
Old 08-21-2014, 20:56   #7 (permalink)
Crazy Poster
Member: 1712008
Sonork: access111
Thanks Meter: 11
Okay now read another play of process... First check if the box shows in the device manager, or com.ports, (by plugin and removing the box cable to notice any change) if all seems well, then remove the serial cable in front of the box $ check again,noting that the box must beep and blink blue/red light when the software is launched , if there seems to be no response from software and the system drivers are up to date and that you've try winxp$ win7 both 32bit ... then there is a problem inside the box or if you have just bought the box then there is a chance that the box's already bad from production or a cloned type. my advice is for you to seek technical advice from an authorized dealer, never try any online hardware solution.
The Following 2 Users Say Thank You to olaniyi For This Useful Post:
Old 08-21-2014, 21:03   #8 (permalink)
Crazy Poster
Member: 1712008
Sonork: access111
Thanks Meter: 11
Also try to use different version including the old ones, if one worked then you may need to update the firmware. And please try it on a clean system that has no box installed cos of driver conflicts , this do happens sometimes when drivers has similar content
The Following User Says Thank You to olaniyi For This Useful Post:
Old 08-22-2014, 02:24   #9 (permalink)
-gayang-'s Avatar
Member: 2041408
Thanks Meter: 38
disconnect your box to your computer for at least 10 minutes then connect and try open miracle software
Old 08-22-2014, 18:33   #10 (permalink)
Member: 706023
Sonork: 100.1647210
Thanks Meter: 75
@olaniyi
I have already done what you said. I can see com port of box in the device manager. I have also checked it with the old versions in the clean system, but the problem still exists.
when I connect the box, there is no beep sound. when the software launches, the red light doesn't blink but the blue one does. The blue one blinks for a few seconds and then the alarm light turns on. Therefore the green and read light are on and an error says buy the box.
Old 08-22-2014, 18:38   #11 (permalink)
Crazy Poster
Member: 1712008
Sonork: access111
Thanks Meter: 11
@olaniyi
please when did you buy the box and have you used it before?
Old 08-22-2014, 19:36   #12 (permalink)
Member: 706023
Sonork: 100.1647210
Thanks Meter: 75
I bought it in 2013 and have been using it since then. I installed version 1.03 in order to repair firmware of box and I can see com port of box in the device manager, but the box software doesn't recognize the com port of box. Is there any way to repair the firmware of box?
Old 08-22-2014, 19:46   #13 (permalink)
Crazy Poster
Member: 1712008
Sonork: access111
Thanks Meter: 11
Wait!!!! Have you consider changing the USB A2B CABLE and if there is other way for firmware problem i'll let you know shortly cos there is a high chance that its a firmware default.
Old 08-22-2014, 19:50   #14 (permalink)
Crazy Poster
Member: 1712008
Sonork: access111
Thanks Meter: 11
And please try Windows7 32bit and is your Windowsxp service pack 3?
Old 08-22-2014, 20:03   #15 (permalink)
Member: 706023
Sonork: 100.1647210
Thanks Meter: 75
I checked it with 4 different A2B cables but no change. I also tried windows 7 and the windows xp that I used is sp3.
The Following User Says Thank You to parvizhamidi For This Useful Post:
Page generated in 0.25807 seconds with 8 queries
