Miracle Box GSMCampus |
08-21-2014, 04:26 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | My Miracle box shows not connected error I created a Logs folder in the directory folder where Miracle software is installed. when I open the software, the light of alarm of the box turns on. I also tried different versions of software, but it didn't work. Is there any solution for the problem? Sent from my SPH-L720 using Tapatalk |
08-21-2014, 16:01 | #4 (permalink) |
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | Are there any supporters working here or not? I have posted a problem yesterday, but haven't received any solutions from the supporters. Is this how you provide us customer service? Sent from my SPH-L720 using Tapatalk |
08-21-2014, 16:03 | #5 (permalink) | |
Crazy Poster Join Date: Jan 2012 Location: ilaro, ogunstate,Nigeria.
Member: 1712008 Status: Offline Sonork: access111 Thanks Meter: 11 | Quote:
...................... ofaj links technology ............................ | |
08-21-2014, 17:14 | #6 (permalink) |
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | Thanks for the replay I have already done all steps. I even installed the software in a new computer, but I am still receiving the same error. Would you please post the other levels? Sent from my SPH-L720 using Tapatalk |
08-21-2014, 20:56 | #7 (permalink) |
Member: 1712008 Status: Offline Sonork: access111 Thanks Meter: 11 | Okay now read another play of process... First check if the box shows in the device manager, or com.ports, (by plugin and removing the box cable to notice any change) if all seems well, then remove the serial cable in front of the box $ check again,noting that the box must beep and blink blue/red light when the software is launched , if there seems to be no response from software and the system drivers are up to date and that you've try winxp$ win7 both 32bit ... then there is a problem inside the box or if you have just bought the box then there is a chance that the box's already bad from production or a cloned type. my advice is for you to seek technical advice from an authorized dealer, never try any online hardware solution. ...................... ofaj links technology ............................ |
The Following 2 Users Say Thank You to olaniyi For This Useful Post: |
08-21-2014, 21:03 | #8 (permalink) | |
The Following User Says Thank You to olaniyi For This Useful Post: |
08-22-2014, 18:33 | #10 (permalink) |
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | @olaniyi I have already done what you said. I can see com port of box in the device manager. I have also checked it with the old versions in the clean system, but the problem still exists. when I connect the box, there is no beep sound. when the software launches, the red light doesn't blink but the blue one does. The blue one blinks for a few seconds and then the alarm light turns on. Therefore the green and read light are on and an error says buy the box. |
08-22-2014, 18:38 | #11 (permalink) | |
.................... ofaj links technology ...................... | |
08-22-2014, 19:36 | #12 (permalink) |
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | I bought it in 2013 and have been using it since then. I installed version 1.03 in order to repair firmware of box and I can see com port of box in the device manager, but the box software doesn't recognize the com port of box. Is there any way to repair the firmware of box? |
08-22-2014, 19:46 | #13 (permalink) |
Member: 1712008 Status: Offline Sonork: access111 Thanks Meter: 11 | Wait!!!! Have you consider changing the USB A2B CABLE and if there is other way for firmware problem i'll let you know shortly cos there is a high chance that its a firmware default. .................... ofaj links technology ...................... |
08-22-2014, 19:50 | #14 (permalink) |
Member: 1712008 Status: Offline Sonork: access111 Thanks Meter: 11 | And please try Windows7 32bit and is your Windowsxp service pack 3? .................... ofaj links technology ...................... |
08-22-2014, 20:03 | #15 (permalink) |
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | I checked it with 4 different A2B cables but no change. I also tried windows 7 and the windows xp that I used is sp3. Sent from my SPH-L720 using Tapatalk |
The Following User Says Thank You to parvizhamidi For This Useful Post: |
