Miracle Box GSMCampus |
10-16-2016, 04:57 | #2 (permalink) |
Freak Poster Join Date: Oct 2007 Location: INSIDE SAMSUNG
Member: 612008 Status: Offline Thanks Meter: 25 | hello sir any help, this my my 1st time to use this box. i hope someone can help me. where is the option for writing imei?? and i try to read the phone always show waiting for usb.. i try to uninstall and reinstall new driver. tia |
10-16-2016, 14:09 | #6 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | this is drivers fault only download from here Miracle Driver Installation 1.00 |
10-17-2016, 04:53 | #9 (permalink) |
Member: 612008 Status: Offline Thanks Meter: 25 | hello sir need your help how to write imei for this phone.. i try to reinstall latest driver but same cannot detect the phone but in other software connecting.. need your advice.tia |
10-17-2016, 07:05 | #10 (permalink) |
Member: 612008 Status: Offline Thanks Meter: 25 | same sir, i run the software as admin but same boss.please help me this is my 1st time to use. tia WARNING : IMEI CHANGE IS ILLEGAL Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set Prolific USB-to-Serial Comm Port (COM60) Please Hold "ON" to connect with the phone... Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set Prolific USB-to-Serial Comm Port (COM60) >>Please Hold "ON" to connect with the phone... |
10-17-2016, 07:42 | #11 (permalink) | |
No Life Poster Join Date: May 2012 Age: 27
Member: 1764566 Status: Offline Sonork: SUSPENDED Thanks Meter: 5,763 | Quote:
If Its Ok Then Plz Try TO Repair In Boot Mode By Tick New BT | |
10-17-2016, 08:16 | #12 (permalink) |
Member: 612008 Status: Offline Thanks Meter: 25 | thanks sir finally the phone is connected but still imei is invalid.. there is another way to fix this problem? tia Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set Prolific USB-to-Serial Comm Port (COM60) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x00E9000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x40000000 Checking IMEI DATA... IMEI1:864851020900719 IMEI2:864851020900701 Verify...Done. >>IMEI OK. |
10-17-2016, 09:59 | #13 (permalink) | |
First You Need To Repair Baseband Kindly Reapir Baseband MTK<Extra Here Fix Baseband Then Repair IMEI Hope It Will Fix | |
10-17-2016, 11:13 | #14 (permalink) |
Member: 612008 Status: Offline Thanks Meter: 25 | same sir i try to fix unknown baseband and repair imei still invalid imei 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set Prolific USB-to-Serial Comm Port (COM60) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x00E9000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x40000000 Waiting for USB Port... if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set Prolific USB-to-Serial Comm Port (COM60) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x00E9000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x40000000 Checking IMEI DATA... IMEI1:864851020900719 IMEI2:864851020900701 Verify...Done. >>IMEI OK. |
