Miracle Box GSMCampus |
03-08-2015, 16:34 | #1 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1559546 Status: Offline Thanks Meter: 10 | need help qmobile a115 flashing problem Definition Applied Waiting for USB Port... Set MTK USB Port (COM34) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... BootData ERR(2): 0_0 Definition Applied Waiting for USB Port... Set MTK USB Port (COM34) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... >>BootData ERR(2): 0_0 |
03-09-2015, 15:59 | #5 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
For Boot Repair Code: you have to disassemble your phone and take pcb out. check there should be some Golden points. check these points there should be written on them Rx,Tx,GND,Vcc,Vcharge etc... check there should be written "COLO" or "KOLO" or "KCOLO" you have to Sold that point with GND After Sold Attach usb now your phone will detect with USB !! and now ready to Flash. In some phones "COLO" or "KOLO" or "KCOLO" not written for those type of phones you have to test all points one by one Short Golden point with GND and attach usb cable which point short with gnd can able to detect your phone by pc is Force Preloader Mode Test Point !! Keep in mind Don't Short Vcc,Vcharge or any other pin which have 4.x Volts also i had tested "Colo" or "Kolo" or "KCOLO" don't have any kind of volts. please conect with me. On Sonork or skype i will try to solved your problem . Regard | |
The Following User Says Thank You to FullFlashPak For This Useful Post: |
03-09-2015, 20:34 | #6 (permalink) | |
Member: 1559546 Status: Offline Thanks Meter: 10 | Quote:
now my fone dead but my phone read frimware ok formate ok with flash toole format ok check nad ok, now tel me point ,COLO, atach to GND r not my sonork id is 100.1627777 | |
03-10-2015, 06:39 | #7 (permalink) |
Member: 782530 Status: Offline Thanks Meter: 8,136 | Set Mobistel USB Port (COM49) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: Nand_NEW_0072 Nand Flash Code: 009800BC(00900066) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Waiting for USB Port... Set MediaTek DA USB VCOM (Android) (COM62) Writing(Nand/eMMC)... W ERR 00: A5 >>W ERR 01: 00000000_000C4600 Brother your nand chip damge . |
