Miracle Box GSMCampus |
04-07-2014, 17:31 | #1 (permalink) |
No Life Poster Join Date: Jun 2013 Location: PK Lahore Panjab
Member: 1965559 Status: Offline Sonork: 100.1622928 Thanks Meter: 1,834 | Nokia 108 only keys blinks Solved with Miracle box Nokia 108 only keys blinks Solved with Miracle box here is test Report... Read flash... Gif Viduo Read flash done... just format blinking problem done B.R |
The Following 7 Users Say Thank You to Mr..bhatti For This Useful Post: |
04-08-2014, 12:28 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: UFI-BOX+EASYJTAG BOX Age: 34
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | Thanks Good Report Akhtar Ali Jatt Format is not a permanent solution after few days set becomes again in blinking ............. |
06-18-2014, 17:46 | #7 (permalink) |
No Life Poster Join Date: May 2012 Location: Sherghati (gaya) Bihar Age: 31
Member: 1761355 Status: Offline Sonork: 0818211 Thanks Meter: 105 | Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM101) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT625A_S0001 Ver: CA01 md:8000 Downloading Boot9 ... Nor/SF Flash Type: [WINBOND] W25Q32BV Nor Flash Code: 00400000(00EF0040) Nor/SF Flash Size: 0x400000 Hex Bytes Nand Flash Type: NOR_NEW_FF00 Nand Flash Code: 00000000 Nand Flash Size: 0x0 Hex Bytes INT/EXT RAM Size: 0xFFFF0000+0x0 Erasing...62 Writing(Nor)... Checking flash... Write OK. >>Total Time: 1 mins 34 s |
