Miracle Box GSMCampus |
10-17-2018, 05:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2153016 Status: Offline Thanks Meter: 29 | oppo a83 problem !!!! (Replied & Closed) Please Remove SIM & Close Wifi Checking Security Searching and Uploading data Starting.. Selected Brand : Oppo Selected Model : OPPO A83(MTK) # Before Start Must Install Drivers. Check Driver : Index of ./__/ # Device Must be off Please Remove Battery & Insert Again # Volume Down then Insert USB Cable Waiting for USB Port... Set MediaTek USB Port (COM8) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6763 SW:0001 Ver: CA01 Downloading Boot8 ... Process Failed.. i try again with Miracle Thunder the program stop and nothing happin after that 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% you can Set Formatting Addr Waiting for USB Port... Set MediaTek USB Port (COM8) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6763 SW:0001 Ver: CA01 >>Downloading Boot8 ... what can i do ?? ps i make new win 7 x64 and installe usb drivers frome support to thankes for help ... Last edited by [SV]; 10-18-2018 at 00:05. Reason: (Replied & Closed) |
10-17-2018, 05:10 | #2 (permalink) |
No Life Poster Join Date: Nov 2011 Location: MIRACLE TEAM
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | First fallow Rules So team able to reply you http://forum.gsmhosting.com/vbb/f715...rules-1930479/ |
10-17-2018, 17:58 | #5 (permalink) |
Member: 2153016 Status: Offline Thanks Meter: 29 | thankes for replay but the program just stoped after this Connected to Phone. CPU: MT6763 SW:0001 Ver: CA01 >>Downloading Boot8 ... ****************************/view/i7i1z...85401.jpg/file the program work fine with x559 infinix ****************************/view/hf6e5...85944.jpg/file so where is the problem with oppo ???? thankes again for help |
10-18-2018, 00:04 | #6 (permalink) |
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Reply to User Oppo A83 Success with Miracle Remember Boot Key is vol- or you also can check Bot key |
The Following 2 Users Say Thank You to [SV] For This Useful Post: |
