Old 04-12-2015, 04:05   #31 (permalink)
Member: 249764
Thanks Meter: 17
Connecting to Phone,Wait..ok
Repair IMEI...
Hardware:redhookbay
Manufacturer:asus
Model:ASUS_T00F
Android Ver:4.4.2
Done
Definition Applied
Repair IMEI...
Hardware:redhookbay
Manufacturer:asus
Model:ASUS_T00F
Android Ver:4.4.2
Done
Definition Applied
Hardware:redhookbay
Board:clovertrail
CPU ABI:x86
Manufacturer:asus
Model:asus_t00f
Android Ver:4.4.2
bootloader ver:unknown
USB config:mtp,adb
User:jenkins
Build number:asus_t00f_ww_user_2.20.40.13_20141105_1055 release-keys
Region:us
Language:en
Chipset:clovertrail
IMEI1:null
IMEI2:null
Root: Rooted(su)
>>Done
miracle team .....plise add suport repair ime asus cipset intel
The Following User Says Thank You to petekere For This Useful Post:
Old 07-03-2015, 15:52   #32 (permalink)
SANBORANN's Avatar
Member: 620829
Sonork: 100.1600720
Thanks Meter: 48
how about cpu sc 7701 and 7702 i need cloning the phone
I made unlocked the true super 2 phone from thailand now phone stuck only true
but now my customer bring the good one to unlock but i need to read flash from the good one and write back to the dead
Old 08-25-2015, 23:36   #33 (permalink)
Member: 1721899
Thanks Meter: 39
BRAND: LG
MODEL: D100
CPU: MediaTech
CPU ID S6572
mtk interface doesn't supported in LG download mode. instead, there is diffrent mode to deal with lg mtk models, so it would be better to insert new module for this platform, till now there is one tool only that can support flashing that model , it's z3x lg mtk tool, I hope miracle will be supported it as soon as possible under the name "MTK LG
Good luck"
The Following User Says Thank You to omarb1989 For This Useful Post:
Old 08-26-2015, 07:40   #34 (permalink)
Member: 2332758
Sonork: 1663896:GsmShafaiT
Thanks Meter: 137
Sir add symphony e5 spd
ADD UNLOCK SUPPORT
PHONE MODEL SYMPHONY E5
Done.
Infor: SPRD3
Initialize boot13...
CPU type: 8810/6820
Flash type: NAND
Flash ID: 009800BA
Flash Model: TOSHIBA TC58NYG1S8C
Flash Size: 0x10800000(264.0M)
Being analyzed,Wait...
256k(spl),1m(2ndbl),256k(params),1m(vmjaluna),9m(m odem),3840k(fixnv),3840k(backupfixnv),5120k(dsp),3 840k(runtimenv),10m(boot),10m(recovery),220m(syste m),160m(userdata),60m(cache),256k(misc),1m(boot_lo go),1m(fastboot_logo),3840k(productinfo),512k(kpan ic),10m(intmemory),512k(simlock)
Analyzed data Failure.
SHOW UNLOCK BUT STILL GMAIL LOCK
Scanning USB Serial port...
SU2Serial Port: COM144
Done.
Infor: SPRD3
CPU type: 8810/6820
Flash type: NAND
Flash ID: 009800BA
Unlocking...
Done.
PLZ ADD THIS SUPPORT
TNX MIRACALE TEAM
The Following 2 Users Say Thank You to gsmshafait For This Useful Post:
Old 09-02-2015, 06:03   #35 (permalink)
sachin.mishra's Avatar
Member: 1856209
Sonork: 100.1626211
Thanks Meter: 44
Lava Arc 24 MT 6261
Write flash
See This Miracle Box 2.16 MTK 6595 Added & SCI 7730 Support format (Discussion Thread)
The Following User Says Thank You to sachin.mishra For This Useful Post:
Old 10-23-2015, 21:46   #36 (permalink)
Member: 2477011
help me root
pls HELP me root my BS MOBILE STARK
TYIA
Old 11-04-2015, 09:35   #37 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: 100.1650339[OFFLINE]
Thanks Meter: 1,006
Intex Aqua Y2 1GB 7731
Intex Aqua Y2 1GB write flash failed
Old 01-22-2016, 19:55   #38 (permalink)
Ouzigzag's Avatar
Member: 1753151
Sonork: 100.1658597
Thanks Meter: 323
Question MTK 8127 not supported ?
Definition Applied
  1. Power Off Phone , Remove Battery, Insert Battery Back
  2. Insert USB cable. In some cases Required Hold BootKey
  3. Use Miracle Boot Key In cases Boot key not Find
  4. Battery Should be Charged more then 50%
  Definition Applied
  you can Set Formatting Addr
  Waiting for USB Port...
  Set PreLoader USB VCOM Port (COM4)
  Please Hold "ON" to connect with the phone...
  Connected to Phone.
  CPU: MT8127 SW:0000 Ver: CA04
  Downloading Boot11 ...
  EMMC Size: 0x0000000000
  Flash Type: EMMC
  INT/EXT RAM  Size: 0x0+0x0
>>Not support Flash ID
The Following User Says Thank You to Ouzigzag For This Useful Post:
Old 01-31-2016, 20:41   #39 (permalink)
DZ-DEVELOPER's Avatar
Member: 2068893
Thanks Meter: 364
Condor W1 [PKT-407] Griffe
CPU: Qualcomm MSM8212
System: Windows Mobile 8.1
Need Operation: Remove User Lock without Factory Data Reset
Old 02-01-2016, 09:30   #40 (permalink)
Member: 2068893
Thanks Meter: 364
Condor F1 [PGN-201]
Condor F2 [PGN-202]
Condor F3 [PGN-203]
CPU: MT6260
Need Operation: Write Firmware Original File Scatter Formula "CFG"
Download Firmware + Loader
Old 02-01-2016, 13:06   #41 (permalink)
Member: 2502523
Thanks Meter: 3
Please add samsung crt read write
Old 02-01-2016, 14:13   #42 (permalink)
Member: 1819592
Thanks Meter: 146
alcatel pop7 imei repair
i need imei repair for alcatel pop7 its showing done when i repair imei but in phone still same imei. and all that kind of cpu imei repair. that is got imei and imei sv.. plz add repair imei..at the moment only sigma tool repair that imei
Old 02-28-2016, 17:58   #43 (permalink)
Member: 2522042
Explain Please
Originally Posted by IMRAN_ANSARI View Post
bro
for iphhone passcode removed we have already released
black box
What is that? Is it something to buy separate? Where can I find it. Thank you.
Old 02-29-2016, 01:39   #44 (permalink)
Crazy Poster
Member: 1492570
Thanks Meter: 4
Phone & new cpu id adding request
phone & new cpu id adding request
Old 03-23-2016, 09:13   #45 (permalink)
Member: 2500215
Thanks Meter: 225
I don't know if my request is much but this feature might be a mind ****ing feature. Please can team consider automated creation of TWRP recovery or Cmw on mtk chipset via USB mode or from extracted boot.img from the phone we wish to create for?
There are good reasons for this custom recovery.
1. It guarantee root via flashing zip files using twrp etc.
2. Dead phones can be boot to recovery which will enable users recover their media files via MTP mode in the twrp.
3. Another reason is because backup taken by twrp is guaranteed.
But if no need as viewed by team. Please do not consider my suggestions.
Sorry for posting off topic.
Page generated in 0.22769 seconds with 8 queries
