Old 12-18-2019, 19:53   #751 (permalink)
Member: 2430286
Sonork: 100.1668015
Please add sprd 9850k
Sent from my Redmi 6 Pro using Tapatalk
Old 12-19-2019, 08:02   #752 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Thanks Meter: 39,695
Coolsand Mega 5 Support
in new update Lenovo K320T
support
The Following User Says Thank You to [SV] For This Useful Post:
Old 12-27-2019, 08:39   #753 (permalink)
Member: 2936907
Vivo v9
[Read Info] EDL mode
1. Phone switched Off
2. Press Vol+ or Vol-,Connect Mobile with USB Cable
Or use specialized USB Cable
Scanning USB Serial port...
Connecting to Phone,Wait..
Done.
CPUID:0x0008C0E1
CPU:MSM8996
Loading the boot,Wait..
BootLoad Error. ID: 0003
>>Please change Model,Try again.
Old 12-27-2019, 20:45   #754 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Reply to User
Done.
CPUID:0x0008C0E1
CPU:MSM8996
http://forum.gsmhosting.com/vbb/f715...-post-1930479/
Fallow Rules
Post Image
write Error
Old 01-08-2020, 14:36   #755 (permalink)
Member: 2244629
Sonork: 2244629
Thanks Meter: 5
please add spd pac file maker or creator and auto select cpu or chip
Please add spd Pac file maker or creator and convertor. Miracle box team, look at this big,big updates no spd Pac file maker and convertor.Finish it all at once.
Old 01-11-2020, 07:59   #756 (permalink)
Member: 2706215
EMMC Size: 0x0747C00000
Flash Type: EMMC
INT/EXT RAM Size: 0x40000/0x80000000
version:8.1.0
brand:TECNO
manufacturer:TECNO MOBILE LIMITED
model:TECNO LB7
Checking IMEI DATA...
No find Phone data(1)
Try Restored IMEI by Format
IF Ok,Then Repair IMEI again!
Old 01-21-2020, 12:53   #757 (permalink)
Member: 2941320
Question qmobile l103 classic, read write not available
hello. this mobile is assebled in AJK, cannot read write , please give some solution
Old 01-23-2020, 06:44   #758 (permalink)
Member: 2936907
Oppo A1k Not Done.. With Vivo Tool ..
Selected model:OPPO A5S/A3/F9(META)
1. Power Off Phone , Remove Battery, Insert Battery Back
2. In some cases Required Vol+,Insert USB cable
3. Battery Should be Charged more then 50%
Android system Need Preloader COM PORT
No need to press any key
If NO Preloader COM PORT,Need Hold Up or Down TO MTK COM POER(Some OPPO modles)
Waiting for USB Port...
Set MediaTek USB Port (COM4)
CPU: MT6765 SW:0000 Ver: CA00
Set OPPO PreLoader USB VCOM (Android) (COM5)
Being read info...
>>Port Err
Old 01-23-2020, 18:27   #759 (permalink)
Member: 1531486
Sonork: nit4sharma
Tambo t2
Tambo t2 after flash imei null
Not done by miracle
Spd 9832
Have a any suggestions
Old 01-24-2020, 16:09   #760 (permalink)
Member: 2941320
hello, please add huawei y520 in miracle thunder.
Old 01-24-2020, 17:43   #761 (permalink)
Member: 2941320
some new qmobile and e-tachi models are assembled in pakistan are not supported in miracle box
Old 01-28-2020, 08:44   #762 (permalink)
Member: 2936907
A1k Not Don Unlock..
2. Insert USB cable. In some cases Required Hold BootKey
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
If NO Preloader COM PORT,Need Hold Up or Down TO MTK Com port(Some OPPO modles)
Set MTK USB Port (COM5)
Set OPPO PreLoader USB VCOM (Android) (COM6)
Being read info...
Being Format userdata...
Sofeware ver:CPH1923_11_A.22_190825_3e5fcc54
>>Done..
Old 01-28-2020, 10:44   #763 (permalink)
Member: 2414769
it cost credit but didnt flash with this error
the phone has no problem becuse i flash it before with global rom in xiaomi miracle
and it cost 10 credit too but phone was like before
2 time cost credit but the phone is still like before
little useless scammer
And Some Required 9008 Test Point
Found Port:COM11
Done.
CPUID:0x000A50E1
CPU:0x000a50e1
Done.
Sending Ping..
Xiaomi Auth Required for This Phone..
Reading Auth Data..
Auth Key : AQAAAFMBAAAxDn6wnUNbG81YCCA1TTzxowiRXg
Sending Data to Server for Calculation..
Writing Auth Key..
Phone Autorized ok..
writing,Wait...
xml error,exit.
Old 01-30-2020, 14:15   #764 (permalink)
Member: 2115061
pls add oppo A1K meta mode
Old 02-14-2020, 06:48   #765 (permalink)
Member: 2244629
Sonork: 2244629
Thanks Meter: 5
please add nokia TA-1034 MTK6261da chip and spd 7701 chip
Page generated in 0.24741 seconds with 10 queries
