Miracle Box GSMCampus |
10-29-2014, 09:55 | #6556 (permalink) |
Freak Poster Join Date: Nov 2011 Location: ALL INDIA
Member: 1695643 Status: Offline Sonork: 1651587:vk Thanks Meter: 90 | micromax a61 cpu7710 pattern lock done with miracle box BR vkgupta96 Last edited by vkgupta96; 10-29-2014 at 10:03. |
The Following 5 Users Say Thank You to vkgupta96 For This Useful Post: |
10-29-2014, 14:13 | #6559 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | spice 5400 hang on logo repair done by miracale box SPICE HANG ON LOGO REPAIR DONE.ONLY WITH FORMAT WITH FLASH FILE DOWNLOAD HERE. spice 5400 mtk - Download - 4shared - ashish gupta BR |
10-29-2014, 17:57 | #6560 (permalink) |
Insane Poster Join Date: Feb 2014 Location: jibannagar,Bangladesh Age: 31
Member: 2137772 Status: Offline Sonork: 100.1652835 Thanks Meter: 51 | Symphony W35 (Mtk6575cpu) Hang On Start Up Problem Solved By wipe data Only With Mira Symphony W35 (Mtk6575cpu) Hang On Start Up Problem Solved By wipe data Only With Miracle box |
10-30-2014, 07:19 | #6561 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Karbonn a51 unlock Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.94 Update:14-10-14 Firmware Version:1.12 Connected OK. Connecting Internet... Network connected error Fuzzy Logic Method is very safe and reliable ! Definition Applied Definition Applied Scanning USB Serial port... SU2Serial Port: COM18 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot13... CPU type: 8810/6820 Flash type: NAND Flash ID: 00EC00BC Flash Model: Samsung K9K4G16Q0M Flash Size: 0x21000000(528.0M) Being analyzed,Wait... Analyzed data OK.(4) Formating... >>Format Completed. |
10-30-2014, 07:25 | #6562 (permalink) |
No Life Poster Join Date: Jun 2011 Location: India Age: 37
Member: 1750704 Status: Offline Thanks Meter: 12,171 | WORLD FIRST AGAIN MMX 106 6582 CPU PATRN LOCK REMOVED WITHOUT USB DEBUG ENABLE NO NEED WIPE NO NEED FLASH BR MIRACLE TEAM |
The Following 13 Users Say Thank You to Harish Gulati For This Useful Post: |
10-30-2014, 08:06 | #6563 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Sict kiran v5 hang logo solved (read/format/imei) Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM110) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor/SF Flash Type: [MX] MX25U3235E Nor Flash Code: 00C20025(00360000) Nor/SF Flash Size: 0x400000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Reading infr(Nor)... The phone information: XPHONE50D_11B_PCB01_GPRS_MT6250_S00.MAUI_11B_W11_3 2_SP_V3_F3.BIN the file not be encrypted Done. Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM110) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor/SF Flash Type: [MX] MX25U3235E Nor Flash Code: 00C20025(00360000) Nor/SF Flash Size: 0x400000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Reading(Nor)... The phone information: XPHONE50D_11B_PCB01_GPRS_MT6250_S00.MAUI_11B_W11_3 2_SP_V3_F3.BIN the file not be encrypted Read OK. Total time: 0 mins 9 s File Save to: E:\CHAINA & ALL OG BRAND\FLASH FILE\1. MTK\MTK 625A\SICT KIRAN V5\XPHONE50D_11B_PCB01_GPRS_MT6250_S00.MAUI_11B_W1 1_32_SP_V3_F3.BIN Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM110) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor/SF Flash Type: [MX] MX25U3235E Nor Flash Code: 00C20025(00360000) Nor/SF Flash Size: 0x400000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Formatting Nor Flash... Format Start Addr: 0x3B5000, Size: 0x4B000 Formatted OK. if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM110) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT625A Ver: CA01 SW:0001 Test Mode, Reading Information From the Phone... W IMEI1 OK: 91124720++++++ R IMEI2 OK: 35171204000000-0 R IMEI3 OK: 35171204000000-0 >>NONE IMEI4 |
10-30-2014, 08:28 | #6565 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Micromax a116 unlock only root 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this 3.Clear code for USB debugging can not manually open 4.With clear code function Cleared password, please recover ROOT Waiting for USB Port... Set Micromax A110 PreLoader USB VCOM Port (COM20) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6589(6583) SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0xE7000000 Flash Type: EMMC INT/EXT RAM Size: 0x0+0x0 Reading ROOT DATA...2780000_600000 C:\Program Files\Miracle Box\MTK6583emmcboot1410301200.img Writing ROOT DATA...2780000_600000 Root OK. Done (Enter Any Pattern To Unlock Screen) total?? 0 mins7 s |
10-30-2014, 11:13 | #6566 (permalink) |
Freak Poster Join Date: Feb 2013 Location: pak karachi sadar
Member: 1949466 Status: Offline Sonork: 100.1625935 Thanks Meter: 258 | Qmobile noir i7 [SIZE="6"] QMOBILE ANDROID 4.4.2 KITKAT ROOT AND INVaLID IMEI done ROOT IMEI REPAIR 100% OK THANKS MIRECLE BOX |
The Following 3 Users Say Thank You to wahab92 For This Useful Post: |
10-31-2014, 13:00 | #6570 (permalink) |
Freak Poster Join Date: Aug 2014 Location: india
Member: 2237851 Status: Offline Thanks Meter: 117 | Intex y11 pattern lock done by miracle box INTEX Y11 PATTERN LOCK DONE AFTER ROOT & WIPE DATA DONE BY MIRACLE BOX |
The Following User Says Thank You to mahi telecom For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
