Unlock Server
Old 05-09-2012, 12:22   #16 (permalink)
Deepesh_Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
How To Work Rx Tx (DP DM) in Mstar CPU
USE DP&DM ON MSTAR
The Following 5 Users Say Thank You to Deepesh_Sharma For This Useful Post:
Old 05-09-2012, 13:27   #17 (permalink)
Member: 1301233
Sonork: 100.1614172
Usb power not enough problem(solv)
USB POWER NO ENOUGH PROBLEM HERE SOLUTION FOR THIS
PROBLEM VIDEO
http://www.youtube.com/watch?v=ltPKFF6cXk4&feature=player_embedded
HOW TO SOLV
WHEN YOU FIND PIN OUT THEN REMOVE BETTRY SUPPLIER AND ATTECH BETTRY (LIKE IMAGE) THEN DO YOUR OPRETION
AND SOLV SUCESSFULLY VIDEO HERE
http://www.youtube.com/watch?v=bZdOLtByDkM&feature=player_embedded
BR-DEEPESH SHARMA( BETA TESTER TEAM)
Old 05-14-2012, 08:00   #18 (permalink)
Harish Gulati's Avatar
Member: 1750704
Sonork: 100.1609090
kenxinda mobile a3 red clour reset without any box
first press sim call 1 key then power
both one
time
then ur phone asking for 2 option
1.phone data will be fully erased
2.phone start normaly
then u press 1 key and center key (menu)
ur proceseing start it willbe take 10 min
(note: Phone btry must be fully chrge or connect with supply of box or any power supply)
br
harish gulati
miracle team
The Following User Says Thank You to Harish Gulati For This Useful Post:
Old 05-14-2012, 09:22   #19 (permalink)
Member: 1301233
Sonork: 100.1614172
many people confuse to formatte i will tell there two ways to formate to phone
MANY MEMBER ASK ME I TRIED FORMATTE THEN NOT SOLV I GIVE SOLUTION HERE TWO TRICK FOR FORMATTE PHONE
TRICK-1 FOR FORMATE MTK(MEDIATEK)
TRICK-2 FORMATE MTK(MEDIATEK)
HERE SOLUTION FOR SPREAD
TRICK-1 FOR SPREAD
TRICK-2 FOR SPREAD
WBR-MIRACLE-BOX TEAM (TRULY FOR CHINA)
DEEPESH-SHARMA
The Following 7 Users Say Thank You to Deepesh_Sharma For This Useful Post:
Old 05-17-2012, 07:21   #20 (permalink)
Member: 1301233
Sonork: 100.1614172
how can we know which set need boot key
one more important post for miracle-box usere's HOW TO WE KNOW WHICH SET NEED BOOT KEY
here image
if you faced this problem then your set need boot key plz try one by one all button
many time boot key is *&#, *#&call,menu key,call key try all buttion for need boot key
wbr- miracle-box team
deepesh sharma
Old 05-17-2012, 09:45   #21 (permalink)
Member: 1750704
Sonork: 100.1609090
IF YOU ARE FACING PROB DURING DO IMEI LIKE NOT ENTER TEST MODE OR NONE IMEI
THEN JUST READ FILE AND START LIKE IMAGE OPTION
HARISH GULATI
MIRACLE TEAM
Old 05-18-2012, 13:48   #22 (permalink)
Member: 1750704
Sonork: 100.1609090
Miracle suite all solution for ur miracle problam
ALL IN ONE MIRACLE SUITE FOR MIRACLE REALTED QUERY
miraclesuite by miracle team harish gulati.rar - 4shared.com - online file sharing and storage - download
HARISH GULATI
MIRACLE TEAM
The Following 4 Users Say Thank You to Harish Gulati For This Useful Post:
Old 05-21-2012, 11:03   #23 (permalink)
Member: 1301233
Sonork: 100.1614172
Here final solution for when find spread cpu pc restart
OUR MANY USER FACED THIS PROBLEM WHEN FIND SPREAD CPU PC WILL RESTART HERE SOME STEP FOR SOLV THIS PLZ FOLLOW US
STEP-1
STEP-2
STEP-3
STEP-4
THEN INSTALL AGAIN MIRACLE-BOX AND INSTALL BOX DRIVER
SOLV YOUR PROBLEM 100%
DEEPESHSHARMA
The Following 2 Users Say Thank You to Deepesh_Sharma For This Useful Post:
Old 05-24-2012, 13:56   #24 (permalink)
Member: 1750704
Sonork: 100.1609090
Spd com flashing(rx tx) without soldring wires
NOW SPD FLASHING WITH COM ON SINGLE CLICK
WITH JACK
http://www.youtube.com/watch?v=TbSQJWesmWM
JUST SEE VIDEO AND IF U FACE PROB CONTACT WITH ME
HARISH GULATI
MIRACLE TEAM
Old 05-29-2012, 07:32   #25 (permalink)
Member: 1301233
Sonork: 100.1614172
You have extend to download limit solved
HI TO ALL MIRACLE-BOX USER THERE ARE MANY USER FACED FILE DOWNLOAD PROBLEM TO DAY I FACED SAME PROBLEM THEN I SOLVED THIS ON THIS PROCESS YOU WILL TRY AND POST RESULT HERE
THIS PROCESS I WILL TRY ON IDM
IF ANY PROBLEM THEN CONTACT ME
NOTE- IF ONE TIME SHOW THIS MGS DOWNLOAD LIMIT THEN THIS PROCESS WILL WORK AFTER 24 HOUR
WBR- MIRACLE-BOX TEAM
DEEPESH SHARMA
Old 05-30-2012, 18:02   #26 (permalink)
Member: 1750704
Sonork: 100.1609090
Please relse on off solution for miracle user
PLEASE RELSE ON OFF SOLUTION FOR MIRACLE USER
http://www.youtube.com/watch?v=muhHBdamnvI
IF ANY PROBLAM CONTACT WITH ANY SUPPORTER OR WITH ME
HARISH GULATI
MIRACLE TEAM
Old 06-09-2012, 06:51   #27 (permalink)
Member: 1301233
Sonork: 100.1614172
Confussion about pid&vid solv here
MANY MIRACLE-BOX USER'S ARE CONFUSE ABOUT FIND PINOUT PID&VID SHOW THEN WAHT'S CPU AND WHICH CPU THEY START TO WORK THEM
SO I WILL FIND HER SOLUTION
SEE HERE CARE FULLY BOTH IMAGE
IMAGE 1ST ON MTK(MEDIATEK)CPU
IMAGE 2ND FOR SPD(SPREADTRUM)CPU
TODAY I HAVE ONLY TWO CPU PHONE WHEN I GET MSTAR CPU THEN POST HERE ALSO MSTAR PID&VID IMAGE
DEEPESH SHARMA
The Following 12 Users Say Thank You to Deepesh_Sharma For This Useful Post:
Old 06-12-2012, 12:17   #28 (permalink)
Member: 1301233
Sonork: 100.1614172
Sigmatel s90 pinout
MANY TIME I HAVE FACED THIS PROBLEM THERE ARE MANY HANDSET CHARGING JACK 40P-5P(NOKIA 5130 JACK) BOX WILL NOT FIND PINOUT AUTOMATIC ITS MTK BASED PHONE AND PCB BORD WILL NOT PRINT ANY RX OR TX POINT THEN I FIND HER PIN OUT HERE IN IMAGE
DEEPESH SHARMA
Old 06-16-2012, 12:05   #29 (permalink)
Member: 1301233
Sonork: 100.1614172
Originally Posted by prashant45 View Post
Welcome to use miracle box(World's First Fuzzy Logic Based Tool)
S/N: >>>>>About
Connected OK.
Fuzzy Logic Method is very safe and reliable !
Definition Applied
Definition Applied
if Input is space, read sn
Waiting for USB Port...
Set port to COM37
Please Hold "ON" to connect with the phone...
CPU??MT6252 Ver: CC01 SW:0101
Read Information From the Phone...
NONE IMEI
Definition Applied
Set port to COM37
>>NONE IMEI
ples help bro
TRY THIS
OR
IF YOU HAVE ANY PROBLEM THEN CONTACT HERE
Our Supporter Worldwide Network And Beta Tester Team
OR IF YOU WANT WE CONTACT YOU THEN POST HERE
http://forum.gsmhosting.com/vbb/f715...t-you-1475214/
DEEPESH SHARMA
Old 07-26-2012, 09:52   #30 (permalink)
Member: 1750704
Sonork: 100.1609090
How to work with rx tx manualy in coolsand
IN THIS POST I WILL SHARE HOW TO WORK WITH
RX TX MANUALY IN COOLSAND CPU
WHN UR JACK DEMAGE AND RX TX NOT FIND
http://www.youtube.com/watch?v=GZDbkkA42O8
MIRACLETEAM
HARISH GULATI
The Following 6 Users Say Thank You to Harish Gulati For This Useful Post:
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.58411 seconds with 11 queries
