Miracle Box GSMCampus |
07-03-2014, 07:00 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q E750 Format dade plz help Please choice other Boot Not support Flash ID >>Circuit bad Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.88 Update:14-06-20 Firmware Version:1.11 Connected OK. Connecting Internet... You use Latest Miracte Software 1.88 Fuzzy Logic Method is very safe and reliable ! ======================= Miracle Box News Miracle Box 1.87 15th June 2014 http://*******/9yDhVh ======[Download]====== Welcome to Miracle CDMA BOSS ADD ON Pack for Mircle Box [LG+ZTE+SAMSUNG+HUWAEI+HAIER+LAVA] for ADD MIRCALE CDMA BOSS ADDON on MIRACLE BOX/MIRCALE EAGLE EYE Download : http://*******/lbb2qt CONTACT www.dealer.amiraclebox.com BR [SV] MIRACLE TEAM ======================= Proud to Say you are Miracle Team User _______________________ Miracle Box Version 1.87 Definition Applied Waiting for USB Port... Waiting for USB Port... No usbport Definition Applied Definition Applied Please Hold "ON" to connect with the phone... Abort by User MTKScaning Pinouts,Please press Power-Key... <<....... Abort by User Definition Applied Definition Applied Please Hold "ON" to connect with the phone... Abort by User Definition Applied Definition Applied Please Hold "ON" to connect with the phone... Abort by User MTKScaning Pinouts,Please press Power-Key... <<#... OK. type: MTK Model:6250 Definition Applied Definition Applied Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CA05 SW:0101 Can Not Enter TestMode Maybe the USB power no enough can not select SafeMode,then into complete mode Definition Applied Definition Applied you can Set Formatting Addr Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CA05 md:8B00 Downloading Boot7 ... Nor/SF Flash Type: [GIGA] GD25LQ128 Nor Flash Code: 00C80060(00180000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x4C000000 Formatting Nor Flash... Format Start Addr: 0xCE0000, Size: 0x320000 Formatted OK. if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Definition Applied Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CA05 SW:0101 Can Not Enter TestMode Maybe the USB power no enough Definition Applied Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CA05 SW:0101 Can Not Enter TestMode Maybe the USB power no enough The File Information: WBG1517Q_0201_PCB01_GPRS_MT6252_S01.1517Q_0201_V19 55.BIN the file not be encrypted >> Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CA05 md:8B00 Downloading Boot7 ... INT/EXT RAM Size: 0x0+0x4C000000 Please choice other Boot Not support Flash ID Circuit bad Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CA05 md:8B00 Downloading Boot7 ... INT/EXT RAM Size: 0x0+0x4C000000 Please choice other Boot Not support Flash ID >>Circuit bad |
07-03-2014, 09:24 | #6 (permalink) | |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote:
The File Information: WBG1517Q_0201_PCB01_GPRS_MT6252_S01.1517Q_0201_V19 43.BIN the file not be encrypted >> MTKScaning Pinouts,Please press Power-Key... <<#... OK. type: MTK Model:6250 Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CA05 md:8B00 Downloading Boot7 ... Nor/SF Flash Type: [GIGA] GD25LQ128 Nor Flash Code: 00C80060(00180000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x4C000000 Verifying Baud... Set Baud:921600 OK. Erasing...255 Writing(Nor)... Write OK. >>Total Time: 5 mins 11 s | |
