Miracle Box GSMCampus |
06-10-2014, 13:09 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Did you try to restore og imei? What condition before flash your set? You have back up before flash? Answerd here then i will provid you solution if you haveback up before write flash then its 100% recover |
06-10-2014, 13:14 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | [QUOTE=Deepesh_Sharma;10366793]Did you try to restore og imei? What condition before flash your set? You have back up before flash? Answerd here then i will provid you solution if you haveback up before write flash then its 100% recover[ Its just stuck on logo aftre write scattre file its working fine but no service or no network also reapir imei but no luck now i dont have backup this phone |
06-10-2014, 13:24 | #4 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Bad luck then need to try with write with nv file no have nv file just moment or try to find set and read file and just write it to faulty phone Last edited by Harish Gulati; 06-10-2014 at 13:39. Reason: REMOVE QUOTE |
06-10-2014, 13:42 | #5 (permalink) | |
Member: 392149 Status: Offline Thanks Meter: 199 | [QUOTE=Deepesh_Sharma;10366828] Quote:
Here is logs Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM48) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6577 SW: E201 Ver: CB00 Downloading Boot8 ... EMMC Size: 0xE9000000 Nor/SF Flash Type: NOR_UNKNOWN INT/EXT RAM Size: 0x0+0x0 Writing(Nand/eMMC)... Writing MBR Writing EBR1 Writing __NODL_NVRAM Writing UBOOT Writing BOOTIMG Writing RECOVERY Writing SEC_RO Writing LOGO Writing ANDROID Writing CACHE Writing USRDATA Writing FAT Write Done. Total time: 7 mins 2 s Last edited by shh_903; 06-10-2014 at 13:49. Reason: Log add | |
