Miracle Box GSMCampus |
04-01-2017, 07:54 | #1 (permalink) |
Insane Poster Join Date: Jul 2009
Member: 1068041 Status: Offline Thanks Meter: 46 | qmobile 3g2 cant flash. (World's First Fuzzy Logic Based Tool) Update:17-01-25 Firmware Version:1.16 Connected OK. Fuzzy Logic Method is very safe and reliable ! License Expire Date: 2018-03-05 Check Authentication... Check the new version. ______________________________ Miracle Box Version 2.46 Qualcomm Extra Power Pack Release: 29th March 2017 ______________________________ www.support.amiraclebox.com Buy 1 year Support Activation BIG BIG UPDATES ON THE WAY Br. [SV] Miracle Team ________[Social Site]_________ http://facebook.com/amiracleteam https://twitter.com/amiracleteam ___________SUPPORT]___________ https://miraclesserver.com ______________________________ MTK NFB File The File Information: HEXING76_512256_11A_PCB01_HSPA_MT6276_S01.V322_01E _CFZZ_QVGA_QMOB_YY5_V01.BIN Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Unstable comport Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek USB Port (COM19) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6276_S0101 Ver: CB00 md:8A00 Downloading Boot7 ... Nand Flash Type: [TOSHIBA] TC58NYG0S8C Nand Flash Code: 009800B1(00800055) Nand Flash Size: 0x8000000 Hex Bytes INT/EXT RAM Size: 0x401004/0x0 >>Writing(Nand)... |
04-01-2017, 08:28 | #3 (permalink) | |
Member: 1068041 Status: Offline Thanks Meter: 46 | Quote:
