Miracle Box GSMCampus |
02-03-2016, 20:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: HUAWEI FRP KEY imei-code
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | qmobile E16 Remove Lock Code Done 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MTK USB Port (COM59) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6260_S0000 Ver: CA00 md:8000 Downloading Boot7 ... Nor/SF Flash Type: [GIGA] GD25LQ128 Nor Flash Code: 00C80060(00180000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Formatting Nor Flash... Format Start Addr: 0xE70000, Size: 0x18E000 >>Formatted OK. |
02-04-2016, 06:36 | #2 (permalink) | |
No Life Poster Join Date: Jun 2011 Location: India Age: 37
Member: 1750704 Status: Offline Thanks Meter: 12,171 | Quote:
also post images bro | |
