Miracle Box GSMCampus |
12-20-2012, 15:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | qmobile e995 dead after format Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes Formatting Nand Flash... Format Satrt Addr??0x4000000, Size: 0x4000000 >>Format nand OK |
12-20-2012, 15:55 | #2 (permalink) | |
No Life Poster Join Date: Jun 2011 Location: India Age: 37
Member: 1750704 Status: Offline Thanks Meter: 12,171 | Quote:
wht prob before keep press on off one minute and also try with full flash | |
12-20-2012, 16:24 | #6 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | bro format again and rebuild imei then post result i upload your file i done this job many time 100% work just format and rebuild |
12-21-2012, 15:05 | #10 (permalink) | |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote: the file must be encrypted wiret file no pw on log; SoftWare Version 1.36 Update:12-12-10 S/N: >>>>>About Firmware Version:1.07 Connected OK. Connecting Internet... You use Latest Miracte Software 1.36 Fuzzy Logic Method is very safe and reliable ! Definition Applied Definition Applied The File Information: TINNO36_10A_GEMINI_PCB01_GPRS_MT6236_S00.E960_MP_F 1_PK_01_21.BIN_FLNH8BCS0QG0MBP_56M the file must be encrypted >> Waiting for USB Port... Set port to COM10 Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes Proceding MTK6236 CPU encryption... the file is no encrypt 1 Writing(Nand)... Write OK. if Not pwr on, Please Format it >>Total time: 4 mins 5 s Or Format no pw on Log; you can Set Formatting Addr Waiting for USB Port... Set port to COM10 Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes Formatting Nand Flash... Format Satrt Addr??0x4000000, Size: 0x4000000 >>Format nand OK | |
12-21-2012, 16:04 | #11 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | now its 100% tested file bro flash and post result E995 QMOBILE Project ID E960_MP_F1_PK_01_21 - Download - 4shared |
12-22-2012, 05:01 | #12 (permalink) | |
wiret flash Miracle box & Volcano Box or GPGDragon but same problem need solved my problem same file errer the file must be encrypted wiret file but phone dead log; SoftWare Version 1.36 Update:12-12-10 S/N: >>>>>About Firmware Version:1.07 Connected OK. Connecting Internet... You use Latest Miracte Software 1.36 Fuzzy Logic Method is very safe and reliable ! Definition Applied Definition Applied The File Information: TINNO36_10A_GEMINI_PCB01_GPRS_MT6236_S00.E960_MP_F 1_PK_01_21.BIN_FLNH8BCS0QG0MBP_56M the file must be encrypted >> Waiting for USB Port... Set port to COM10 Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes Proceding MTK6236 CPU encryption... the file is no encrypt 1 Writing(Nand)... Write OK. if Not pwr on, Please Format it >>Total time: 4 mins 9 s and Format but phone dead Log; you can Set Formatting Addr Waiting for USB Port... Set port to COM10 Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes Formatting Nand Flash... Format Satrt Addr??0x4000000, Size: 0x4000000 >>Format nand OK Last edited by kabul; 12-22-2012 at 05:07. | |
12-30-2012, 08:46 | #14 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | My other phone hang on logo format ok but still hang on logo You use Latest Miracte Software 1.37 Fuzzy Logic Method is very safe and reliable ! Definition Applied Definition Applied Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes Verifying Baud... Set Baud:921600 OK. Reading Size: 0x8400000 Reading(Nand)... Read OK. total?? 32 mins38 s File save to:C:\Users\Kabul\Desktop\e995 Definition Applied Please Hold "ON" to connect with the phone... CPU: MT6236 Ver: 8A03 SW:8A00 Test Mode, Reading Information From the Phone... Formatting as a safe mode >>OK ! (items= 60) Wiret flash file phone dead The File Information: TINNO36_10A_GEMINI_PCB01_GPRS_MT6236_S00.E960_MP_F 1_PK_01_21.BIN_FLNH8BCS0QG0MBP_56M the file must be encrypted >> Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes Verifying Baud... Set Baud:921600 OK. Proceding MTK6236 CPU encryption... the file is no encrypt 1 Writing(Nand)... Write OK. if Not pwr on, Please Format it >>Total time: 13 mins 59 s |
