Miracle Box GSMCampus |
02-21-2017, 07:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | QTab V100 MT6580 FRP Reset By Format Done By Miracle Box+Key QTab V100 MT6580 FRP Reset By Format Done By Miracle Box+Key Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM8) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x039D000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x80000000 Formatting Nand Flash... Format Satrt Addr??0x4FA0000, Size: 0x100000 >>Format nand OK(Android Need to wait a few minutes the phone is switched) Br Suny125 Miracle Team |
The Following User Says Thank You to Suny125 For This Useful Post: |
