Miracle Box GSMCampus |
11-23-2012, 14:14 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Mumbai Age: 43
Member: 523792 Status: Offline Thanks Meter: 96 | samsung s iii 9300 copy adroid 4.1 restore original imei with miracle box old vertion Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.28 Update:12-09-28 S/N: >>>>>About Firmware Version:1.05 Connected OK. Please check the network. Fuzzy Logic Method is very safe and reliable ! if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Changing Android IMEI: 1.Turn on the phone by battery 2.Enter the menu: Set --> development --> USB debug(Activate) 3.Insert USB cable or define USB pinout, install android driver 4.Select function IMEI(switched on) 5.Input IMEI1 or IMEI2 , press START Definition Applied Waiting for USB Port... Waiting for USB Port... none usbport, maybe driver not installed Definition Applied Waiting for USB Port... Abort by User Waiting for USB Port... Abort by User No usbport if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Changing Android IMEI: 1.Turn on the phone by battery 2.Enter the menu: Set --> development --> USB debug(Activate) 3.Insert USB cable or define USB pinout, install android driver 4.Select function IMEI(switched on) 5.Input IMEI1 or IMEI2 , press START Definition Applied Connection Done CPU: mt6573 MODEL: 9300 VSN: 4.1 Wait ... WRITING IMEI1 & IMEI2.. JOB DON Done Definition Applied Connection Done CPU: mt6573 MODEL: 9300 VSN: 4.1 Wait ... WRITING IMEI1 & IMEI2.. JOB DON Done Definition Applied |
The Following 3 Users Say Thank You to DIN231080 For This Useful Post: |
