Miracle Box GSMCampus |
05-29-2016, 10:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: MIRACLE TEAM
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Solution Vcom Driver & Show Waitting for USB Port & 64 Bit Os Driver Issue You need to Uninstall your Driver and Install New. _________________________________________ First Uninstall ALL Old Drivers Open Device Manager Connect Mobile with Miracle Show Vcom Post > Right Click Uninstall also Delete Driver Option again Connect Mobile Connect with Miracle Install New Driver > Give Path to your Driver Windows 10 Driver is not Pass Signature So you need to Disable Unsigned Driver How to Disable Unsigned Driver See Video :- https://www.youtube.com/watch?v=71YAIw7_-kg after Install New Driver __________________________________________________ _________ 1st 2nd 3rd 4th Miracle Connect 65XX Fine See Video : How To Disable Driver Signature Enforcement in Windows 10 Download Windows MTK VCOM USB Preloader Drivers All Windows Br Miracle Team Last edited by [SV]; 05-29-2016 at 10:20. |
The Following 39 Users Say Thank You to [SV] For This Useful Post: |
10-04-2017, 03:03 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Emmc & Ufs Chips Age: 42
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | If Any user Use 64 Bit Os And Have Issue In Driver Installation Follow This Follow Following Steps After Success Restart Just Install Any Driver U Want Use the following steps to disable driver signature enforcement. Click the Start menu and select Settings. Click Update and Security. Click on Recovery. Click Restart now under Advanced Startup. Click Troubleshoot. Click Advanced options. Click Startup Settings. Click on Restart. Now Install Any Driver U Want Issue Solved |
The Following 5 Users Say Thank You to chinchik For This Useful Post: |
