Miracle Box GSMCampus |
02-13-2014, 13:21 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: B A N G L A D E S H Age: 31
Member: 1686868 Status: Offline Sonork: 100.1625990 Thanks Meter: 85 | spd 6531 usb pinfind ok but not found driver & not booting solution as gmobile g206. problem spd 6531/ 6530 usb dected ok boot key ok but driver not responding. many time browse perfect driver but not detected driver. step by step solution 1. find boot key if need a broken usb cable. 2. open your phone find (dp) (dm) or (d+) (d-). 3. you know about usb cable pinout (+5v) (d+) (d-) (gnd) 4. connect properly (d+) (d-) & gnd without (v+). 5. put your battery on your phone press boot key If needed & connect pc press power button. 6. select proper driver. 7. command your box than connect at same process. |
09-18-2014, 14:48 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | 1st press boot key and insert cable then battery if not connect reinsert battery check and post 99% connecting ok |
01-15-2016, 15:30 | #7 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
Before Post Read Carefully http://forum.gsmhosting.com/vbb/f715...users-1953994/ Post Your Problem By New One Thread Dont Stolene Other Pepole Thread Without Scanshort We Dont Provide You Correct Solution
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. | |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
