Miracle Box GSMCampus |
07-24-2013, 04:56 | #5 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Info must check in android section which cpu Steps:- 1.select spd 2.Choose type : SPD8810/6820 3.CHEK ANDROID AND CHECK USB CABLE 4.HANDSET SHOULD BE SWITCHED OFF WITH BATTERY INSERTED 5.FILL BOTH IMEI AND PRESS START BUTTON 6.CONNECT USB TO YOUR HANDSET 7: WHEN SU2Serial Port: Com XX shown press "POWER ON BUTTON" 8: And when it shows "Test mode, OK" at this stage you have to "REINSERT USB CABLE" from your handset.. NOW ALL DONE |
