Old 08-14-2019, 12:56   #1 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 185
x606c The Boot not support the Phone, or CPU Bad. Select other Boot
Hi.
Old 08-14-2019, 14:16   #2 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 185
INFINIX X606c the boot not support the phone or bad cpu selecte other boot
Hi to all
Here is full log trying with both boot 11 and boot 15 same problem the boot not support the phone or bad cpu selecte other boot
Definition Applied
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Insert USB cable. In some cases Required Hold BootKey
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
Waiting for USB Port...
Set MTK USB Port (COM9)
Connecting to Phone,Wait..
Connected to Phone.
CPU: MT6580 SW:0000 Ver: CA00
Downloading Boot11 ...
The Boot not support the Phone, or CPU Bad. Select other Boot.
Definition Applied
Connected to Phone.
Modle Error(May be need Auth file)..
Downloading Boot(External) ...
Definition Applied
Connected to Phone.
NB: phone dead after auto wifi update
Old 08-14-2019, 17:26   #3 (permalink)
vishnudatt's Avatar
Member: 1306196
Sonork: 100.1654602 (08104048625)
Thanks Meter: 959
Try without costom setting.......
Old 08-14-2019, 19:18   #4 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 185
Thanks for your reply first.
Here is log without custom setting boot 8 boot 11 and boot 15
also with or without vol+ - pressed same problem
Old 08-14-2019, 22:43   #5 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 185
Hi miracle team.
Here is another infinix x609 phone was hange at fastboot mode and restart so I flash it and unchech preloader so as to phone not went totally dead but phone flashed ok and went dead really not accept any flash any more
Here is flashing log
Definition Applied
Unstable comport
Definition Applied
Set MediaTek PreLoader USB VCOM (Android) (COM7)
Connected to Phone.
Downloading Boot8 ...
Definition Applied
Connected to Phone.
EMMC Size: 0x03A3E00000
Flash Type: EMMC
INT/EXT RAM Size: 0x20000/0x40000000
Writing(Nand/eMMC)...
Writing LK
Writing LK2
Writing BOOT
Writing RECOVERY
Writing LOGO
Writing ODMDTBO
Writing VENDOR
Writing TEE1
Writing TEE2
Writing SECRO
Writing SYSTEM
Writing CACHE
Writing USERDATA
Checking Sum...
Write Done.
Total time: 4 mins 38 s
after phone went dead here is log
Definition Applied
Connected to Phone.
Old 08-15-2019, 13:49   #6 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 185
X606c and x609
Hi ser.
what's next step ? what should i do?
Old 08-15-2019, 16:28   #7 (permalink)
Member: 2476740
Thanks Meter: 210
All are Secure Boot Phones.
Originally Posted by ramoon20 View Post
Hi ser.
This are secure boot Phones that work with only signed Firmare.If you flash Signed Phone with the Readed firmware,the phone will surely be Dead.
Some of them will not accept even Dongraded signed firmware.You must flash them with the same Build or Higher.
Page generated in 0.36176 seconds with 8 queries
