Miracle Box GSMCampus |
09-19-2014, 14:25 | #1 (permalink) |
Major Poster Join Date: Jul 2008 Location: DELHI, INDIA Age: 39
Member: 816353 Status: Offline Thanks Meter: 9 | zen x13 dead after format after format set is dead not even connecting to pc here is logs:- Scanning USB Serial port... SU2Serial Port: COM84 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot9... CPU type: 6531A Flash type: NOR Flash ID: 00EF0040(00160000) Flash Model: W25Q32BV Flash Size: 0x400000(4.0M) reading,Wait... Read Completed. Definition Applied Scanning USB Serial port... SU2Serial Port: COM84 Connecting to Phone,Wait.. Please RePower on & off Definition Applied Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Definition Applied Scanning USB Serial port... SU2Serial Port: COM84 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot9... CPU type: 6500 Flash type: NOR Flash ID: 00EF0040(00160000) Flash Model: W25Q32BV Flash Size: 0x400000(4.0M) Formating... Format Completed. Definition Applied Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. |
09-19-2014, 16:49 | #2 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | First of all always make back your phone then try to format now you need ok working file try to find and flash |
The Following User Says Thank You to maanarman For This Useful Post: |
