Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #17 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Online Sonork: 100.1587334 Thanks: 5,390
| S5830i PIN or Password after startup, usb debugging not enabled S5830i PIN or Password after startup, usb debugging not enabled 1. put phone in recovery and select S5830iroot.zip from sd and install 2. after power on conect phone to rj45 and box 3. in asansam select comport and press Bypass 4. u are in full menu without data loss 5. profit this is another pit model that dont need debug enabled tested on firmware S5830iXXLA2 needed file http://uloz.to/xDQpxzM/s5830iroot-zip |
| The Following 12 Users Say Thank You to dr_moosavi For This Useful Post: |
| | #18 (permalink) |
| I9300 repair boot manual I9300 repair boot manual ================= -Insert External SD Card to normal phone to copy Bootloader to SD card -Open asansam tool -Select model and press run -Press boot repair button -Click Open bootfile button and load GT-I9300_Boot_Recovery.tar file -Enter download mode with the normal phone(SD Card inserted) -Connect the phone to PC, using USB cable -Click Write boot file button to copy bootloader to the phone -Disconnect the phone from PC -Press exit and press on boot repair button again -Click Open boot file button and load GT-I9300_Boot_Recovery.tar file -check send to sdcard option to copy bootloader to SD Card -Enter download mode with the normal phone(bootloader was copied before), and connect it to PC again -Click Write boot file button to copy bootloader to the SD Card -After downloading turn off the phone and remove the SD Card (This SD card will be used to recover boot of the phone) -Disassemble the ‘No Power’ phone, but connecting the LCD with PBA, to check the LCD if boot recovery is successfully done -Insert SD card(bootloader was copied) to the PBA -Connect the PBA with usb cable and power supply, with the POWER OFF -Short R313 resistance(HQ uses tweezers to short the resistance) -Turn on the PBA, and REMOVE THE SHORT between 3 to 6 seconds from turning on the PBA -After approximately 5 seconds, you can see message on the LCD boot recovery was succeeded -Turn off the pba, and remove SD Card -Assemble the phone, and enter download mode -Download Full S/W including PIT, PDA, CSC and PHONE About RESET PATTERN &REMOVE AND RESET USER CODE ========================================== For all operation you must root phone manualy (by kernel) Download ========= ASANSAM_1.8.2_to_1.8.3_Updater.exe ========================== ASANSAM_1.8.2_to_1.8.3_Updater.exe(HIPFILE) ================================ Available in ASANSAM SHELL =================== GT-I9300_Boot_Recovery.tar ==================== GT-I9300 Repair Manual Picture ===================== [B]GT-I9300 Orginal Manual(PDF) ==================== Last edited by dr_moosavi; 10-17-2012 at 09:05. |
| The Following 2 Users Say Thank You to dr_moosavi For This Useful Post: |
| | #19 (permalink) |
| How to use Asansam updater? How to use Asansam updater? Before using this updater be sure you have installed ASANSAM 1.8.2 ![]() After run updater click upgrade button after that button disabled and process started after finishing uprdae button enabled then you can use last asasnsam |
| The Following User Says Thank You to dr_moosavi For This Useful Post: |
| | #20 (permalink) |
| How to Root Galaxy S3 How to Root Galaxy S3 SCH-I535(Verizon) ![]() Power off the phone Press Volume down + Center + Power button insert usb to phone(download mode) select model and press run press flash button select Tar file in pda press write flash button root successfully Download(torrent file) [/B] How to root Galaxy S3 SGH-T999(T-Mobile) ![]() Power off the phone Press Volume down + Center + Power button insert usb to phone(download mode) select model and press run press flash button select Tar file in pda press write flash button copy cwm zip file to sdcard Press Volume UP + Center + Power button(RECOVERY MODE) select zip file for update reset phone root successfully File download How to Root Sprint/AT&T Galaxy S3 SPH-L710,SGH-I747 ![]() Power off the phone Press Volume down + Center + Power button insert usb to phone(download mode) select model and press run press flash button select Tar file in pda press write flash button copy cwm zip file to sdcard Press Volume UP + Center + Power button(RECOVERY MODE) select zip file for update reset phone root successfully File download |
| | #21 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2011 Location: Iran
Member: 1707100 Status: Online Sonork: 1590245/1587178 Thanks: 502
| P7300 manual: check all options Select PIT file(p5_0614.pit) Put the Tablet into Download mode: Press Volume Down + Power for 10 Sec, then press Volume Up Key Connect USB cable to Tablet and PC. After the program detect the tablet you can Click write button and wait. After the tablet restart remove USB cable and click Reset button. Now uncheck Re-Partition option only Select BOOTLOADER file: BCT_P5_20110705_UNIFICATION.tar Again put the Tablet into download mode like first time then connect USB cable. When the program detect it you can click write button and wait. After the tablet restart remove USB cable and click Reset button. At this step you have to select three files in the following order : PDA: CODE_P7300xxxxx_CL537948_REV00_user_low_ship_16G.t ar PHONE: MODEM_P7300xxxxx_REV_00_CL1055164.tar.md5 CSC: CSC_P7300xxxxx_CL531616_REV00_user_low_ship_16G.ta r.md5 Put the Tablet into Download mode: Press Volume Down + Power for 10 Sec, then press Volume Up Key. Connect USB cable to Tablet and PC. After the program detect the tablet you can Click write button and wait. The program will update all the files then reboot the Tablet. After all is done you can do Full Reset by this code *2767*3855#. tnx to tsar3000 Last edited by dr_moosavi; 10-17-2012 at 09:03. |
| The Following User Says Thank You to Asansam dongle For This Useful Post: |
| | #22 (permalink) |
| About permission denied in New root/unroot Code: Prepairing ...OK Device Found! Root Procedure Started! Prepairing ROOTFILE ... Fail! [Err:0] Permission denied! Operation Completed Operation Time: 00:00:04 |
| | #23 (permalink) |
| How To Reset Pattern How To Reset Pattern Select model press run insert usb cable to phone check enable usb debugging insert sdcard to phone check mount sdcard press root new method button and wait for finish root successfully check root (open cmd /type adb shell/type su) press reset pattern button reset pattern successfully Code: ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Model : GT-S5670 Manufacturer : samsung Brand : samsung CPU info1: : armeabi GSM Baseband Version : S5670XWKT6 Build Version : 2.3.6 Country : GB Language : en Build ID : GINGERBREAD Time-Zone : Asia/Tehran Root User : dpi Sales Code : DBT Country Code : DBT Built Date : Mon Mar 5 10:21:11 KST 2012 ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:06 Code: ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Removing Pattern Lock ... OK Android Pattern Lock Removed. ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:20 |
| | #24 (permalink) |
| ASF OneClick Unlock BootLoader Method(SONY) How to? -------- - First select One of Model listed Above - Going to Service #1 Tab - Press Phone Info to Initialize Needed Parameters for Unlock BootLoader - Now Click on Unlock Via Server - Connect Your Phone In FastBoot Mode - Wait Procedure Complete Notes: ------- - This Procedure is Server Based so You Need Have Internet Connection For That - Depend On You Internet Connection Speed/Quality this Job Can Take 60 Seconds Up to 380 Seconds so Please Be Patient - Because of some Limitations You Can Unlock Only 3 Phones In Period of 15 Minutes - This Procedure is Free |
| | #25 (permalink) |
| About Root 2.3.x (New method root) Support models : Code: Samsung Galaxy Mini GT-S5570 Samsung Galaxy Mini GT-S5570B Samsung Galaxy Mini GT-S5570I Samsung Galaxy Mini GT-S5570L Samsung Galaxy Mini GT-S5571 Samsung Galaxy Gio GT-S5660 Samsung Galaxy Gio GT-S5660M Samsung Galaxy Gio GT-S5660L Samsung Galaxy Gio GT-S5660V Samsung Galaxy Fit GT-S5670 Samsung Galaxy Fit GT-S5670B Samsung Galaxy Fit GT-S5670L Samsung Galaxy Ace GT-S5830 Samsung Galaxy Ace GT-S5830B Samsung Galaxy Ace GT-S5830C Samsung Galaxy Ace GT-S5830D Samsung Galaxy Ace GT-S5830i Samsung Galaxy Ace GT-S5830L Samsung Galaxy Ace GT-S5830M Samsung Galaxy Ace GT-S5830T Samsung Galaxy Ace GT-S5830Z Samsung Galaxy Ace GT-S5839i Samsung Galaxy Duos GT-S6802 Samsung Galaxy Y Duos GT-S6102 Samsung Galaxy Y Duos GT-S6102B Samsung Galaxy Pocket GT-S5300 Samsung Galaxy Pocket GT-S5302 Samsung Galaxy Y GT-S5360 Samsung Galaxy Y GT-S5360B Samsung Galaxy Y GT-S5360L Samsung Galaxy Y GT-S5360T Samsung Galaxy Y GT-S5363 Samsung Galaxy Y GT-S5369 Samsung Galaxy Xcover GT-S5690 Samsung Galaxy Xcover GT-S5690M Samsung Galaxy Xcover GT-S5690L Samsung Galaxy W GT-I8150 Samsung Galaxy W GT-I8150B Samsung Galaxy 551 GT-I5510 Samsung Galaxy 551 GT-I5510B Samsung Galaxy 551 GT-I5510L Samsung Galaxy 551 GT-I5510M Samsung Galaxy 551 GT-I5510T Samsung Galaxy ProGT-B7510 Samsung Galaxy Pro GT-B7510B Samsung Galaxy Pro GT-B7510L Samsung Galaxy M Pro GT-B7800 Samsung Galaxy Y Pro GT-B5510 Samsung Galaxy Y Pro GT-B5510B Samsung Galaxy Y Pro GT-B5510L Samsung Galaxy Y Pro Duos GT-B5512 Samsung Galaxy Y Pro Duos GT-B5512B Manual : Select model Goto Android Service select root 2.3.x in one click root/unroot press do it select update.zip file after reboot press reboot system now root successfully Last edited by dr_moosavi; 10-17-2012 at 09:02. |
| | #26 (permalink) |
| F.A.Q Q. How Can i Unlock/Change Imei I9300 and N7100? A. for that Do these Steps 1) Root your Phone 2) Install Root Explorer Application or any other Good File Manager (it Must Capable to Accsess Root Folder of Phone) 3) Run that Filemanager and be sure you are granted as super user then backup efs folder and factory folder these 2 folders contains these files/folders in normal phones Code: efs
.files
bluetooth
drm
FactoryApp
imei
wifi
.nv_core.bak
.nv_core.bak.md5
.nv_data.bak
.nv_data.bak.md5
.nv_state
00000000.authtokcont
gyro_cal_data
h2k.dat
nv.log
nv_data.bin
nv_data.bin.md5
redata.bin
wv.keys Code: factory
.files
bluetooth
drm
FactoryApp
imei
wifi
.nv_core.bak
.nv_core.bak.md5
.nv_data.bak
.nv_data.bak.md5
.nv_state
gyro_cal_data
h2k.dat
nv.log
nv_data.bin
nv_data.bin.md5
redata.bin
wv.keys
4) Put this backup in safe place and then continue to your work 5) Enable USB Debugging (systems > Developers Options > USB Debugging) 6) For Both Unlock/Repair Imei you must fill Imei so enter your imei 7) connect micro uart cable to ASB Box or any UART Interafce you want 8) select that UART COM in selct Port in ASANSAM soft 9) click on Direct Unlock for unlocking and Repair Imei for Repairing Imei 10) Connect USB Cable to Phone and wait for next step 11) after you see Disabling Security ...Done! Rebooting... OK! Remove USB Cable from Phone and Connect Micro UART cable to Phone you have 40 seconds to doing this 12) Wait till Procedure end 13) after that Phone going Factory Reset but some times it not happen if its not happen it's recommend to doing this your self (*2767*3855#) Q. When I Unlock/Repair IMEI on I9300/N7100 i got "Cant Found Any Patch for This Phone Version ...." message how can i do? A. thats because your phone modem patch not exist in "C\ASANSAM2\DATA\Loaders\Patches" for that doing these steps 1) Press Direct Unlock/Repair Imei you got that message another time its okay now just see what is your PDA/CSC/Phone version you have for example you have phone with these versions PDA Version : I9300XXALEF CS Version : I9300OXEALE4 Phone Version : I9300XXLEF if you have flash file with these versions check that what is your file type (One Package or Not) if its one package try extract that with 7zip and get modem.bin file from that if its non one package extract MODEM_I9300XXLEF_REV02_REV04_CL1147871.tar.md5 and get modem.bin file from that 2) now on ASANSAM soft in Menu select "Settings > Modem Patch Generator" 3) new window appear Select your Modem file(modem.bin) and in 'Enter Modem Patch File Name' section enter name of your patch NOW SEE YOUR LOG AND ENTER PHONE VERSION AS PATCH MODEM NAME (WITH OUR EXAMPLE: I9300XXLEF) 4) click on Patch Modem and wait till message Done appear 5) if every thing be ok your patch file created and moved to "C\ASANSAM2\DATA\Loaders\Patches" it named 'USERCREATE_XXXXXXXXXXXXX.bin' for our example 'USERCREATE_I9300XXLEF.bin' 6) now retry Direct Unlock/Repair IMEI |
| | #27 (permalink) | |
| How To Patch modem I9300,N7100?(Video) How To Patch modem I9300,N7100 ? Quote:
| The Following 5 Users Say Thank You to dr_moosavi For This Useful Post: |
| | #28 (permalink) |
| ROM extract IZArc is the best way to extract zip, rar,tar and many other archives for free Easy Manual : ![]() you can use izrac tool for build tar file or extract |
| | #29 (permalink) |
| What is External Database For Qualcomm MSL Bypass? F.A.Q [B] Q. What is External Database For Qualcomm MSL Bypass? A. When You Unlock Some Qualcomm Phones like S6500D,S6500,S5670, etc. if Software have information About That Phone Modem(Baseband) Version Procedure Doing job so fast (Below 3 Seconds) but if dont information exist for that phone modem version Software Begin Reading that from Phone and its take more Time (for some Phones more than 15 Minutes) so we decide to put a external database for our user and for describe it's work we give you an example Assume you have one S6500 Phone in hand and want to unlock it when you connect it to software if Phone Baseband information exist in our Internal Database you got fast answer but if it's not it searching for needed data when it found that and unlock your phone this Baseband Information Saved on External Database so when you connect another phone with same baseband version software dont search inside phone anymore because you have that in your external database so your time was saved Q. Where Can i Found This External Database File? A. it exist on "C:\ASANSAM2\DATA\" File Named "Bypass_db.ini" Q. I Unlock Many Phones and now i have very rich Database can i share it with another user? A. Sure you can but first you need send your Database File to us for Verifying for that just email it to asansambox@gmail.com |
| The Following 6 Users Say Thank You to dr_moosavi For This Useful Post: |
| | #30 (permalink) |
| How to repair baseband on i9305 without any box? How to repair baseband on i9305 without any box? Solution(Asansam box) : Select model(is same by i9300) press flash download i9305 repair file select repair file in pda insert usb cable to phone(download mode) press write flash baseband repair successfully(press *#06# now) ZIP PASSWORD : only asansam box ------------------------------------------------------------------- Solution(odin) : open odin Odin3 3.04 download i9305 repair file select repair file in pda insert usb cable to phone(download mode) press write flash baseband repair successfully(press *#06# now) ZIP PASSWORD : only asansam box |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 10 | 03-11-2013 15:27 |
| Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 09-16-2011 13:43 |
| Unlock Manual! | MrProdent | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 05-12-2004 09:13 |
| About 5110 & Winlock | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 11-08-1999 02:54 |
| Nokia 5110 & 6110 Schemics | MyKy | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 08-06-1999 08:36 |
