Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #31 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks: 5,398
| About Read PIT About Read PIT ============== This ability allowing you to Read-out PIT file From some Samsung Android Phones its good for that phones with not release PIT file from Samsung for using that you just need Enter phone in Download Mode then connect USB Cable to phone and hit On Read PIT after a while phone reset to Normal Mode and your Phone PIT File extracted |
| The Following User Says Thank You to dr_moosavi For This Useful Post: |
| | #32 (permalink) |
| ASANSAM Dongle work with plenty of UART Interfaces (SPT,Z3X,NS Pro,Octopus,UST Pro, etc..) IMEI REPAIR S2 - CONNECT YOUR (SPT,Z3X,NS Pro,Octopus,UST Pro, etc..) TO PC - IN ASANSAM SOFTWARE SELECT (SPT,Z3X,NS Pro,Octopus,UST Pro, etc..) COMPORT IN SELECT PORT SECTION (YOU MUST DO THIS BEFORE HIT REPAIR IMEI BUTTON) - READ CAREFULLY INSTRUCTION THAT SHOWED UP AFTER HIT REPAIR IMEI - AFTER JOB DONE TRY LEARN THIS INSTRUCTION FOR AVOIDING CONFUSING ON NEXT SIMILAR PHONE |
| The Following 2 Users Say Thank You to dr_moosavi For This Useful Post: |
| | #33 (permalink) |
| About Restore Orginal EFS Data ===================== If you have not done any work on phone and efs with other tool(Adb Command and write damage efs) will restore original efs and no need to dump and write efs with other boxes(Add Other Models in Next Versions) About Repair Unknown Baseband ====================== If these solutions not working for you try to Reflash it with different Versions then Retry and dont forget this problem can be Hardware Issue -Need Root and Enable Usb Debugging -Not Work on All Custom Firmware -Added UB File Soon ======================== |
| | #34 (permalink) |
| Notes ------- About N8000 Unlock/Repair IMEI Unlock Procedure for This Model is Same as I9300,N7100 but there is one problem exist here and it's about UART Cable, for this you need build your cable all things you need is: 1) Unused NOKIA FBUS Cable (8 Pin) (RJ45 Part) 2) One P1000 USB Cable (30 Pin Socket) now in order to use which interface you want to use: Download that attachment below this schematic created by Ns-Team for Ns-Pro Interface so if you want to use Ns-Pro or UFS as interface build your cable exactly like this schematic but if you use another interface (ASB Box,Z3X,UST Pro,etc,...): all thing is same Ns Pro Interface just in RJ-45 Part you must use Pin 2,3 as RX/TX instead 4,5 in NsPro Last edited by dr_moosavi; 12-05-2012 at 07:11. |
| | #35 (permalink) |
| About I9300,N7100 New (Unlock/Repair) Method We Add two Options in Setting TAB About these Models -Create Modem Patch From Phone Modem -Save Modem Patch for reliable of our users and for avoiding confusing about create Modem Patch We Built Internal Automatic Modem Patch Generator in Our Soft How that Work: if you check Create Modem Patch From Phone Modem option if Patch Not Found for your Phone Software read modem from phone in (Unlock/Repair) Process and built patch Modem for that so if you want use this option it recommended to reflash phone first for better answer if you check Save Modem Patch That Patch Created in (Unlock/Repair) Process saved in "C:\ASANSAM\DATA\Loaders\Patches" IMPORTANT NOTE: MODEM PATCH CREATE METHOD IN THIS VERSION IS COMPLETELY DIFFERENT FROM OLDER VERISON SO ALL PATCH MODEM FILES YOU HAVE IN PREVIOUS VERSIONS IS NO LONGER REQUIRED AND NEED TO USE NEW ONES INSTEAD SO BE CAREFUL Last edited by dr_moosavi; 12-05-2012 at 07:05. |
| | #36 (permalink) |
| How to Reset google account (unblock pattern button) How to Reset google account (unblock pattern button) This Method Working on most android phones(samsung) and Not supported all model
| | #37 (permalink) |
| How to Reset pattern ? How to Reset pattern ? Ops models(Galaxy Fit , Gio , Ace) Old version :
pit models(Galaxy s , note , s II , S III) All version :
UART auto ignition cable powered by GPGIndustries
| | #38 (permalink) |
| Q:Why we use unblock pattern button? A:Too many pattern attempts!(pattern lock is block) ![]() ::::::::::Manual:::::::::::::::::::::::::::::::::: ::::::::::::: -Select Model(Most Android phones Supported) -Goto Android Service Tab -Press Unblock Pattern button -Insert usb to phone(Need Root and Usb debugging) -Wait for Step 1 (Phone rebooted now) -Wait For Step 2 (phone rebooted now) -Enter Default Account after rebooted ::::::::::::::::::::::::::::::::::::::::: asansamdongle@gmail.com asansam2012 ::::::::::::::::::::::::::::::::::::::::: -Set new Pattern lock on phone -press Continue on asansam -Wait for Step3 -Phone rebooted now -unblock pattern successfully Important : This method not working on all android phones OPS models : old version no need usb debugging new version nee usb debugging(2.3.6 , 2.3.7 , 4.x.x) Pit Models : All version need usb debugging |
| | #39 (permalink) |
| Hang on logo ops models : Mini S5570, Ace S5830, Gio S5660 , Pop i559, 5 i5500, Fit S5670,... can't repair after : 1-Full flash with all box 2-Tar flash with all box 3-Erase boot and repair then full flash Solution.......................................... .....................
| | #40 (permalink) |
| N8000 Combo Cable Schematic for Asb BOX N8000 Combo Cable Schematic for Asb BOX ![]() ![]() |
| The Following 7 Users Say Thank You to dr_moosavi For This Useful Post: |
| | #41 (permalink) |
| * How to Unlock S3770? Select Your UART Interface COMPORT then turn off the phone and click on direct unlock after that connect cable to phone if phone not going in TAT mode hit power button for 5 sec. |
| | #42 (permalink) |
| ** How Fix imei in I727/I727R ? - Enter *#7284# in DialPad - in Appeared Window select Qualcomm USB Settings - check RMNET + DM + MODEM - (If Phone Not Restart itself Do it) - After Phone Power Up Connect USB cable and install needed driver - Fill Your Phone Label IMEI and click on OK |
| | #43 (permalink) |
| About Dump & Restore ------------------------ Need Root Need enable usb Debugging Q : Why do we use the radio? A : it fix network,wifi problems or in some ways Improve them and it effecting on battery saving and more another things. About Unlock & Lock Bootloader --------------------------------- Turn Off your phone Select Unlock from Bootloader unlock in Android service tab then click on Do it Button in asansam Put your phone into Fastboot mode(Hold Volume Up Key + Volume Down Key then press Power Key) Connect Phone to your PC via USB cable and install driver About One Click Root ---------------------- elect Your Desire option in Android Root in Android Service tab then click on Do it in these two following models they have unique methods For I9250 & P8110 First download root files from ASANSAM Support area then select these file when program request and wait till operation complete [/B][B]*GT-I9250 File *GT-P8110 File Turn Off your phone Put your phone into Fastboot mode(Hold Volume Up Key + Volume Down Key then press Power Key) Connect Phone to your PC via USB cable and install driver |
| | #44 (permalink) |
| About 4.1.2 Root =========== Add Root Android 4.1.2 for Samsung Phones We add new solution for this we test on few models and we got good result but we can't access to all android phones so we add this in BETA TEST(asansam users please test with new phones and send report to Sonork 100.1587178) About 4.1.2 Unbrick ============= Select model Press Unbrick button(you can use same model too) Select Unbrick file(You can download all new Unbrick file Here) Insert usb to phone(unbrick mode or download mode) Install driver Press unbrick |
| | #45 (permalink) |
| About Read Pattern code ================ Need Enable Usb Debugging(NO NEED MOST OPS MODELS) Need Root Need Internet Connection Without Lose All data Code: Prepairing ...OK Device Found! Reading Pattern Lock ... OK Fetching Data ...OK Analyzing Data ...OK Hash : 7BF73061D4030CB2D1828D4AFB7F99478F8089DF Connecting to Calculation Server...OK Verify... OK Pattern Lock Sequence : 325896 Operation Completed Operation Time: 00:00:06 ![]() About Restore PB(Please read carefully) ============ ----This option and Button is for only phones that startup is ok but phone show unknown baseband and when go to recovery mode show u E: failed to mount /efs (Invalid argument) Only ----Please read manual before use this button ----Never dont risk and use this Method for failed to mount /data or failed to mount /system problem |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 10 | 03-11-2013 15:27 |
| Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 09-16-2011 13:43 |
| Unlock Manual! | MrProdent | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 05-12-2004 09:13 |
| About 5110 & Winlock | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 11-08-1999 02:54 |
| Nokia 5110 & 6110 Schemics | MyKy | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 08-06-1999 08:36 |
