HUA GOLD Old BY HUA TEAM |
10-08-2013, 12:46 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: HP Mnla,Philippines Age: 38
Member: 247410 Status: Offline Thanks Meter: 161 | Asansam dongle run time error [SLOVED NOW] i already send pm and contact with sonork please check the atachment always encountered this error..thank's Last edited by dr_moosavi; 10-10-2013 at 09:42. |
10-08-2013, 12:54 | #2 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | unistall all about asansam remove c:/asansam2 folder install 2.2.8 full setup install 2.3.5 open asansam.exe select type dongle(unikey or smart card) press run OR check on other pc or contact to reseller for change dongle(is damaged) THIS IS REQUEST DLL(ATTACHED) AND WHY SELECT UNIKEY AFTER OPEN ASANSAM?DO YOU SURE DONGLE IS UNIKEY? THIS IS UNIKEY |
The Following User Says Thank You to Asansam Box For This Useful Post: |
10-08-2013, 18:42 | #6 (permalink) | |
Freak Poster Join Date: Apr 2012 Location: dubai ++ kerala ++ thalassery
Member: 1745727 Status: Offline Sonork: 100.1617904 Thanks Meter: 66 | Quote:
you have not solved your problem i will help you br i have sole more than mor time thiis error the asansam teeem the nuberone help teeem ok you have any problem with asansam cotact me on sonork id ok brr | |
10-09-2013, 04:27 | #7 (permalink) | |
Member: 247410 Status: Offline Thanks Meter: 161 | Quote:
There is no 2.2.8 set up available in support Please check Thanks | |
10-09-2013, 08:22 | #8 (permalink) | |
ASANSAM_Rev2.2.8 | |
The Following User Says Thank You to sweathasreekant For This Useful Post: |
10-09-2013, 09:52 | #9 (permalink) | |
Problem Solved....Thank's | |
