Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Asangsm Dongle
Old 11-01-2012, 08:55   #31 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
How To Patch modem I9300,N7100
I9300 patch modem by asansam box - YouTube
n7100 patch modem by asansam box - YouTube
The Following User Says Thank You to dr_moosavi For This Useful Post:
Old 11-01-2012, 12:45   #32 (permalink)
chand_gee's Avatar
Member: 668050
Sonork: 100.1590375
hi
i m new user you ask galaxy s3 unlock pattern is require root and debugging
if a phone have pattern lock and not rooted how we can root
and this operation will lost all data or not
Old 11-01-2012, 15:39   #33 (permalink)
Asansam dongle's Avatar
Member: 1707100
Sonork: 1590245/1587178
hi
You need root and enable usb debugging for this model
please use hard reset
Old 11-04-2012, 05:49   #34 (permalink)
Member: 1834422
hi
i am new user asansam box how flash s3310i ?
Old 11-05-2012, 12:26   #35 (permalink)
Member: 821945
Sonork: 56422
how pattern unlock i9000
i am many time tried above method
i got fail
asangsm box is new any other setting are there.
please help me
Old 11-05-2012, 12:35   #36 (permalink)
Member: 1707100
i got fail
you must use bypass pattern
select model
select interface port
insert rj45 cable to phone(UART auto ignition cable powered by GPGIndustries only)
press on bypass pattern
bypass successfully
Old 12-03-2012, 13:50   #37 (permalink)
Member: 904809
Sonork: 100.1615464
hi,sir today i buy a new asan sam box,i need help about unknow base band,plz for a newbie user,how to recover step by step,if possible,with image or video,,thanks,,sir
i9100,,unknow base band,,
Old 12-03-2012, 14:00   #38 (permalink)
Member: 1707100
software solution :
Open ubtool and check all method(need root and usb debugging)
you must check on all firmware version (if not working) and change imei after repair baseband( 004999010640000)
hardware solution :
write dump by jtag or check u100 and u300 ic
Old 12-03-2012, 14:03   #39 (permalink)
Member: 904809
Sonork: 100.1615464
Turn-on the Phone Goto 'Settings > Application > Development'
And Check 'Usb Debugging' Then Connect Usb Cable To Phone And
Install Needed Driver.
Prepairing ...OK
Device Found!
Reading Phone Informations ...
Model : GT-I9100
Android Version : 2.3.6
PDA Version : I9100XXKL1
CS Version : I9100OXAKL1
Phone Version : NULL
IMEI : NULL
Baseband Version : NULL
GSM Baseband Version : NULL
Checking Root ...OK
Phone Root OK. Continue..
Prepairing EFS Data... OK
Rebooting to Recovery Mode... OK
After Recovery Menu Appeared Please Wipe and Factory Reset Your Device from recovery menu then reset your phone
Waiting for Device ...
Device Found!
Initializing NVM ... OK
Resetting NVM Permission ... OK
Finalizing ... OK
Phone Reset Done!
Operation Completed
Operation Time: 00:01:41
at this way ,plz check my logs,
i check all methods,,also i check hardware ,but all are ok
Old 12-03-2012, 14:46   #40 (permalink)
Member: 1707100
why use restore efs?
please check by 2.3.4 , 2.3.5 , 2.3.6 , 4.0.0 version too
Old 12-03-2012, 15:29   #41 (permalink)
Member: 904809
Sonork: 100.1615464
dear sir,plz help for new users,
i am doing some thing wrong,
i don,t know ,root and unroot
the software is asking for root yr phone,
have a look,,,also asking for mmc external,
what is this procedure ,unknown base band,
its mean,mmc external inserted in phone,
plz step by step,for first mobile, thabks,,br
Prepairing ...OK
Device Found!
Model : GT-I9100
Android Version : 2.3.3
PDA Version : I9100JPKF3
CS Version : I9100OJPKF2
IMEI : NULL
Checking Root ...OK
Phone Root Fail. Please Root Your Phone.
Operation Completed
Operation Time: 00:00:04
Old 12-03-2012, 17:16   #42 (permalink)
Member: 904809
Sonork: 100.1615464
dear sir how to to root wih asan ,i9100,,any video,,plz i am still waiting,,
can u help me on team viewer,plz
Old 12-03-2012, 18:14   #43 (permalink)
Member: 904809
Sonork: 100.1615464
plz chek this logs,still unknown base band,
Prepairing ...OK
Device Found!
Model : GT-I9100
IMEI : NULL
Checking Root ...OK
Prepairing Red Method ...OK
Reading EFS ...OK
Analyzing EFS ...OK
Restoring EFS ...OK
Finalizing ...OK
Phone Reset Done!
Operation Completed
Operation Time: 00:00:27
Old 12-03-2012, 18:33   #44 (permalink)
Member: 904809
Sonork: 100.1615464
correct me sir.
i have no mmc instaled in phone,
also don,t know ,about unknown base band repair
so plz correct me,i today buy this box speacilly for this phone,
plz check logs
Before Using This Tool Check and Be Sure :
1) Your Phone Has Complete ROOT Access
2) Your Phone Must be in AirPlane Mode
3) SDCard Insreted in Phone and be Mounted
4) BusyBox Already Installed in Your Phone
Prepairing ...OK
Device Found!
Model : GT-I9100
IMEI : NULL
Checking Root ...OK
Prepairing BROWN Method ...OK
STEP1 ... OK
STEP2 ... OK
Phone Reset Done!
Operation Completed
Operation Time: 00:00:15
in sw window instructions,that
plz check logs
what about this plz help
Old 12-03-2012, 19:56   #45 (permalink)
Member: 904809
Sonork: 100.1615464
why u keep silence,i have problem ,and u only looking,
when i instal any other fimware ,with out 2.3.6
its need for root
what to do,
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.37019 seconds with 11 queries
