HUA GOLD Old BY HUA TEAM |
01-12-2016, 00:16 | #48 (permalink) |
Junior Member Join Date: Jun 2011 Location: Iran
Member: 1588605 Status: Offline Thanks Meter: 1 | Screen Lock (Unlock Samsung FRP) In 8 Seconds 100 % OK Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM15 Initialize Phone ... OK Prepairing... OK Reading PIT Data ...OK Analizing PIT Entries... OK Pit Entry Num: 32 Unocking FRP... OK Resetting... OK Operation Time: 00:00:08 |
01-14-2016, 17:44 | #50 (permalink) |
No Life Poster Join Date: Dec 2013 Location: ecuador
Member: 2078045 Status: Offline Thanks Meter: 151 | other box faile asansam writhe ok ok ok Certificate Parameteres Retrived. Writing Certificate Procedure Started. --------------------------------------------------------------------------------------------------------------------------------------------------------------- For Android 2.x.x: 1- Turn-on the Phone Goto 'Settings > Application > Development' 2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone For Android 4.x.x and Above: 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! --------------------------------------------------------------------------------------------------------------------------------------------------------------- Waiting For Device... OK Please Tap on 'OK' in 'Allow Usb Debugging;' Pop-up on Device Screen! Device Status: [ONLINE] Model : SM-G900M Manufacturer : samsung Serial No. : RF8F804G3FM PDA Version : G900MUBU1ANE2 CSC Version : G900MUWA1ANE3 SW Version : G900MUBU1ANE2 Android Version : 4.4.2 Build ID : KOT49H IMEI : Sales/Country Code : COM Built Date : Sat May 10 02:45:02 KST 2014 Checking Root Permission... OK Prepairing... OK Writing AT Commander... OK..OK -> 9732197C5D9DDD80EFFF4EEFDB8A8F8EB276F748 Bypassing MSL... OK..OK..OK Writing Certificate 1... OK..OK..OK..OK..OK..OK..OK..OK..OK..OK..OK..OK Cleaning Environment... OK Rebooting ... OK Stopping ADB Service... OK Operation Time: 00:03:42 |
The Following 3 Users Say Thank You to spd3 For This Useful Post: |
01-21-2016, 12:58 | #55 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2519049 Status: Offline Sonork: [email protected] Thanks Meter: 1 | very best very best |
01-23-2016, 12:15 | #56 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2207478 Status: Offline Thanks Meter: 0 | I have problem when setup ver. 3.0.2 and 3.0.1 i got run-time error, i use update as below : 1. i run the update file and its extracts in c:\anansam3 folder 2. i run the program after that, then i got run-time error. 3. i copy all files in anansam3 folder to anansam2 folder 4. i run the program after that, again i got the run-time error Please provide update instructions (step by step) not all user are using your box long time, there is some new user like me and there is no guides (you should provid instruction for how to install the program, install driver, and how to use it). now i can use only verstion 2.5.5 awaiting your support Last edited by mmyousif2000; 01-23-2016 at 12:25. |
01-23-2016, 18:26 | #57 (permalink) | |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
