Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA GOLD Old
HUA GOLD Old BY HUA TEAM
Old 01-06-2016, 01:54   #46 (permalink)
paabu12's Avatar
Member: 605364
Thanks Meter: 36
Alternative download
Originally Posted by Hua Supporter View Post
Can we have an alternative download link as 4shared is a little confusing for me
Old 01-06-2016, 06:00   #47 (permalink)
Member: 1371251
Thanks Meter: 14
Hi please upload a mega
Thank
Old 01-12-2016, 00:16   #48 (permalink)
Member: 1588605
Thumbs up Screen Lock (Unlock Samsung FRP) In 8 Seconds 100 % OK
Searching For Phone [SAMSUNG USB PORT]... OK
Phone Found on COM15
Initialize Phone ... OK
Prepairing... OK
Reading PIT Data ...OK
Analizing PIT Entries... OK
Pit Entry Num: 32
Unocking FRP... OK
Resetting... OK
Operation Time: 00:00:08
Old 01-13-2016, 21:32   #49 (permalink)
adi sukmono's Avatar
Member: 695310
Thanks Meter: 144
cant i downgrade shv e250s with this...long time nt support imei for this model too,,
tq team
Old 01-14-2016, 17:44   #50 (permalink)
Member: 2078045
Thanks Meter: 145
other box faile asansam writhe ok ok ok
Certificate Parameteres Retrived.
Writing Certificate Procedure Started.
For Android 2.x.x:
1- Turn-on the Phone Goto 'Settings > Application > Development'
2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone
For Android 4.x.x and Above:
1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number'
2- Return to General Tab Tap on Developer Options
3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone
IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME!
Waiting For Device... OK
Please Tap on 'OK' in 'Allow Usb Debugging;' Pop-up on Device Screen!
Device Status: [ONLINE]
Model : SM-G900M
Manufacturer : samsung
Serial No. : RF8F804G3FM
PDA Version : G900MUBU1ANE2
CSC Version : G900MUWA1ANE3
SW Version : G900MUBU1ANE2
Android Version : 4.4.2
Build ID : KOT49H
IMEI :
Sales/Country Code : COM
Built Date : Sat May 10 02:45:02 KST 2014
Checking Root Permission... OK
Prepairing... OK
Writing AT Commander... OK..OK -> 9732197C5D9DDD80EFFF4EEFDB8A8F8EB276F748
Bypassing MSL... OK..OK..OK
Writing Certificate 1... OK..OK..OK..OK..OK..OK..OK..OK..OK..OK..OK..OK
Cleaning Environment... OK
Rebooting ... OK
Stopping ADB Service... OK
Operation Time: 00:03:42
The Following 3 Users Say Thank You to spd3 For This Useful Post:
Old 01-18-2016, 05:35   #51 (permalink)
Member: 2199518
Sonork: warlen brew
Add repary imei sony xperia?
Old 01-18-2016, 06:15   #52 (permalink)
Member: 2123276
Sonork: 100.1673695
Thanks Meter: 275
what about flesh file support?
Old 01-21-2016, 09:59   #53 (permalink)
Member: 1781818
Sonork: 100.1652308:ashaq
Thanks Meter: 126
where is new setup attest 20 days ago you give setup give new setup and please add some hot modles
Old 01-21-2016, 09:59   #54 (permalink)
Member: 1781818
Thanks Meter: 126
about asansam setup
please add support area in new setup
Old 01-21-2016, 12:58   #55 (permalink)
Member: 2519049
very best
very best
Old 01-23-2016, 12:15   #56 (permalink)
Member: 2207478
I have problem when setup ver. 3.0.2 and 3.0.1 i got run-time error,
i use update as below :
1. i run the update file and its extracts in c:\anansam3 folder
2. i run the program after that, then i got run-time error.
3. i copy all files in anansam3 folder to anansam2 folder
4. i run the program after that, again i got the run-time error
Please provide update instructions (step by step) not all user are using your box long time, there is some new user like me and there is no guides (you should provid instruction for how to install the program, install driver, and how to use it).
now i can use only verstion 2.5.5
awaiting your support
Old 01-23-2016, 18:26   #57 (permalink)
Hua Supporter's Avatar
Member: 2179353
Thanks Meter: 15,757
change card reader and send report again
Old 01-23-2016, 20:28   #58 (permalink)
Member: 2207478
Thanks Hua Supporter for your reply,
I tried 3.0.2 but i got same message
Old 01-24-2016, 15:23   #59 (permalink)
Member: 2207478
as usual support is sleeping
Old 01-25-2016, 10:24   #60 (permalink)
Member: 1961397
Thanks Meter: 3
it gives me this error ?????
list model file corrupted
how to solve it plz
Page generated in 0.49584 seconds with 7 queries
