Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #32 (permalink) |
| Junior Member ![]() Join Date: Feb 2007
Member: 453466 Status: Offline Thanks: 1
| T959 Hi, Just got software but quite dont understand how to use it, can you please help have t959 bricked after flash. Please give detailed process to unbrick phone dead will not connect....Please help |
| | #33 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2001 Location: Roma Age: 38
Member: 5926 Status: Offline Thanks: 134
| Where I find UB Black file for UBTool? First 5 methods didnt work. Code: UBTool Rev1.0.3 By ASAN-GSM TEAM --------------------------------------------- Important Note: Before Using This Tool Check and Be Sure : 1) Your Phone Has Complete ROOT Access 2) Your Phone Must be in AirPlane Mode ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing Red Method ...OK Reading EFS ... Fail [Err:0] Permission denied! Operation Completed Operation Time: 00:00:26 ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing Red Method ...OK Reading EFS ...OK Analyzing EFS ...OK Restoring EFS ...OK Finalizing ...OK Phone Reset Done! Operation Completed Operation Time: 00:00:34 ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing BLUE Method ...OK Reading NV DATA ...OK Analyzing NV DATA ...OK Restoring NV DATA ...OK Finalizing ...OK Phone Reset Done! Operation Completed Operation Time: 00:00:26 ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing ORANGE Method ...OK Checking NV DATA STEP1 ...OK Checking NV DATA STEP2 ...OK Checking NV DATA STEP3 ...OK Checking NV DATA STEP4 ...OK Rebuilding NV DATA (1) ...OK Rebuilding NV DATA (2) ...OK Rebuilding NV DATA (3) ...OK Restoring NV Data ...OK Finalizing ...OK Phone Reset Done! Operation Completed Operation Time: 00:00:24 ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing GREEN Method ...OK STEP1 ... OK STEP2 ... OK Phone Reset Done! Operation Completed Operation Time: 00:00:16 ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing BROWN Method ...OK STEP1 ... OK STEP2 ... OK Phone Reset Done! Operation Completed Operation Time: 00:00:15 |
| | #34 (permalink) |
| Found it, Thank you! Prepairing ...OK Device Found! Prepairing BLACK Method ...OK Model : GT-I9100 Serial No. : NULL Baseband Version : NULL GSM Baseband Version : NULL Bootloader Version : unknown Build Version : 2.3.5 Repairing EFS ... OK Phone Reset Done! Operation Completed Operation Time: 00:00:15 Still need repair, I guess is hw problem, I will dismantle and check it. |
| | #35 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2011
Member: 1637268 Status: Offline Sonork: 1606882 Thanks: 177
| hitherto not understand whats the difference? between AsanSam dongle ub and tool box can explain please which should I buy if UB dongle AsanSam or Tool Box? regards |
| | #36 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2011 Location: Iran
Member: 1707100 Status: Offline Sonork: 1590245/1587178 Thanks: 501
| Quote:
ubtool(unknown baseband tool) is free active in asansam box or dongle | |
| The Following User Says Thank You to Asansam dongle For This Useful Post: |
| | #39 (permalink) |
| Junior Member Join Date: Sep 2012
Member: 1807779 Status: Offline Thanks: 0
| Hi I have a question about this tool do i need the asansam box? or something else to use this to repair my nulled phone imei? and does it restore the sgs2 nulled imei? when i am dailing *#06# there is no imei sadly thanks in advance. |
| | #42 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 396421 Status: Offline Thanks: 88
| then is hardware failure. for example asansam rebuild and restore efs and nvam - this is software solution: sometimes works and sometimes not, this depends on problem in phone. if not work with asansam via software solution, try by jtag, this is jtag-solution. if then still imei is null, then is hardware failure and i think eMMC chip is damaged and must be replaced. |
| | #43 (permalink) |
| i dont have asansam yet i am asking if its works for sgs2 as mainly i some how manage to screw my sgs and sgs2 and i think that i might failed with jtag as i think i didnt conntected the wires right on the cable and its small plate and tap the sgs2 copied it from some vid that i saw :S didnt found any schematics for that so i was thinking that asansam ub tool can help me and if ub tool rly can restore nulled imei i think i'll buy it it just i dont want to buy it and then find out that it wont work on my phone :S |
| | #44 (permalink) | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:06 |
| About 5110 & Winlock | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 11-08-1999 02:54 |
| I am looking for information about GSM-CABLES.NE | DUPOND | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 08-03-1999 15:29 |
| need reference about spterminator&andreww bennet | king76 | The Market Feed Back | 3 | 08-03-1999 15:25 |
| Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 07-06-1999 23:47 |
