HUA GOLD Old BY HUA TEAM |
03-09-2015, 07:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | g530h wipe efs ok but imei remain 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 6- (Install All Needed Driver) -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : SM-G530H Android Version : 4.4.4 PDA Version : G530HDCU1ANL3 CS Version : G530HOLB1ANL3 Phone Version : G530HXCU1ANL3 IMEI : 357575061395950 S/N : R51G147RF0N Checking Root ...OK Phone Root OK. Continue.. Back Up Security AREA1... OK Back Up Security AREA2... OK Back Up Security AREA3... OK Reading QCN Started! Prepairing... OK Searching for Phone ...OK Preparing Phone on COM111 Reading Phone Information ... Build No : MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1 IMEI : 357575061395950 ESN : B0000000 Prepairing... OK..OK Prepairing RFNV... OK Retriving RFNV Items... OK Reading RFNV Items Value... OK Reading NV Items Value... OK Reading NV SIM 1 Items Value... OK Reading NV SIM 2 Items Value... OK Retriving Provisioning Items... OK..OK..OK..OK Read QCN Procedure Finished. Reading QCN Finished! Rebooting... OK! Waiting For Device... Device Found! Wiping EFS... OK..OK Extracting QCN... OK.OK Write QCN Procedure Started... Searching for Phone ...OK Preparing Phone on COM111 Reading Phone Information ... Build No : MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1 IMEI : 357575061395950 ESN : B0000000 Prepairing... OK..OK..OK..OK..OK..OK..OK..OK..OK Writing 'EFS' Item... OK..OK Writing 'NVM' Item... OK Writing 'NVM (SIM1)' Item... OK Writing 'NVM (SIM2)' Item... OK Writing 'Provisioning' Items... OK Write QCN Procedure Finihed. Rebooting... OK! Operation Time: 00:05:06 but imei remain same |
03-09-2015, 07:26 | #2 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | -------------------------------------------------------------------------------------- 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 6- (Install All Needed Driver) -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : SM-G530H Android Version : 4.4.4 PDA Version : G530HDCU1ANL3 CS Version : G530HOLB1ANL3 Phone Version : G530HXCU1ANL3 IMEI : 357575061395950 S/N : R51G147RF0N Checking Root ...OK Phone Root OK. Continue.. Back Up Security AREA1... OK Back Up Security AREA2... OK Back Up Security AREA3... OK Wiping EFS... OK..OK Rebooting... OK! Operation Time: 00:00:16 still same old imei |
03-09-2015, 08:52 | #3 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Enable skip restore backup qcn and then try again http://forum.gsmhosting.com/vbb/f716...nload-1907815/ |
03-09-2015, 10:28 | #5 (permalink) | |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
not help | |
03-09-2015, 11:14 | #6 (permalink) |
Freak Poster Join Date: Dec 2012 Location: bangladesh
Member: 1852501 Status: Offline Sonork: 100.1646032 Thanks Meter: 55 | |
03-10-2015, 11:09 | #12 (permalink) |
No Life Poster Join Date: Jan 2013 Location: searching........ Age: 38
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Same Problem -------------------------------------------------------------------------------------- 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 6- (Install All Needed Driver) -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : SM-G530H Android Version : 4.4.4 PDA Version : G530HXCU1AOA2 CS Version : G530HOJV1AOA1 Phone Version : G530HXCU1AOA2 IMEI : 357575060361003 S/N : R51G12EAZVH Checking Root ...OK Phone Root OK. Continue.. Back Up Security AREA1... OK Back Up Security AREA2... OK Back Up Security AREA3... OK Wiping EFS... OK..OK Rebooting... OK! Operation Time: 00:00:10 -------------------------------------------------------------------------------------- 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 6- (Install All Needed Driver) -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : SM-G530H Android Version : 4.4.4 PDA Version : G530HXCU1AOA2 CS Version : G530HOJV1AOA1 Phone Version : G530HXCU1AOA2 IMEI : 357575060361003 S/N : R51G12EAZVH Checking Root ...OK Phone Root OK. Continue.. Back Up Security AREA1... OK Back Up Security AREA2... OK Back Up Security AREA3... OK Wiping EFS... OK..OK Rebooting... OK! Operation Time: 00:00:11 |
The Following User Says Thank You to jkmobile53 For This Useful Post: |
03-10-2015, 11:59 | #13 (permalink) | ||
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
g530h/dv not supported Quote:
The Following 2 Users Say Thank You to Asansam Box For This Useful Post: |
