HUA GOLD Old BY HUA TEAM |
01-05-2015, 07:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | g900f write cert failed Code: 2015/01/04 - 22:08:43 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:08:43 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/04 - 22:08:43 : 2- Return to General Tab Tap on Developer Options 2015/01/04 - 22:08:43 : 3- And Check 'Usb Debugging' ON 2015/01/04 - 22:08:43 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/04 - 22:08:43 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/04 - 22:08:43 : 6- (Install All Needed Driver) 2015/01/04 - 22:08:43 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:08:48 : Prepairing ...OK 2015/01/04 - 22:08:48 : Device Found! 2015/01/04 - 22:08:48 : Reading Phone Informations ... 2015/01/04 - 22:08:48 : 2015/01/04 - 22:08:48 : Model : SM-G900F 2015/01/04 - 22:08:49 : Android Version : 4.4.2 2015/01/04 - 22:08:49 : PDA Version : G900FXXU1ANG2 2015/01/04 - 22:08:49 : CS Version : G900FOJV1ANG2 2015/01/04 - 22:08:49 : Phone Version : G900FXXU1ANG2 2015/01/04 - 22:08:49 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:08:49 : S/N : R58F80P5H7F 2015/01/04 - 22:08:49 : Checking Root ...OK 2015/01/04 - 22:08:49 : Phone Root OK. Continue.. 2015/01/04 - 22:08:51 : Back Up Security AREA1... OK 2015/01/04 - 22:08:52 : Back Up Security AREA2... OK 2015/01/04 - 22:08:53 : Back Up Security AREA3... OK 2015/01/04 - 22:08:53 : Reading QCN Started! 2015/01/04 - 22:08:53 : Prepairing... OK 2015/01/04 - 22:08:53 : Searching for Phone ...OK 2015/01/04 - 22:08:53 : Preparing Phone on COM68 2015/01/04 - 22:08:53 : Reading Phone Information ... 2015/01/04 - 22:08:53 : Build No : MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 2015/01/04 - 22:08:53 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:08:53 : ESN : B0000000 2015/01/04 - 22:08:54 : Prepairing... OK..OK 2015/01/04 - 22:08:54 : Prepairing RFNV... OK 2015/01/04 - 22:08:57 : Retriving RFNV Items... OK 2015/01/04 - 22:09:12 : Reading RFNV Items Value... OK 2015/01/04 - 22:10:34 : Reading NV Items Value... OK 2015/01/04 - 22:12:56 : Reading NV SIM 1 Items Value... OK 2015/01/04 - 22:15:20 : Reading NV SIM 2 Items Value... OK 2015/01/04 - 22:15:40 : Retriving Provisioning Items... OK..OK..OK..OK 2015/01/04 - 22:15:40 : Read QCN Procedure Finished. 2015/01/04 - 22:15:42 : Reading QCN Finished! 2015/01/04 - 22:15:43 : Rebooting... OK! 2015/01/04 - 22:15:43 : 2015/01/04 - 22:15:43 : Waiting For Device... 2015/01/04 - 22:15:52 : Device Found! 2015/01/04 - 22:15:53 : Wiping EFS... OK..OK 2015/01/04 - 22:15:58 : Extracting QCN... OK.OK 2015/01/04 - 22:15:58 : Write QCN Procedure Started... 2015/01/04 - 22:15:58 : Searching for Phone ...OK 2015/01/04 - 22:15:58 : Preparing Phone on COM68 2015/01/04 - 22:15:59 : Reading Phone Information ... 2015/01/04 - 22:15:59 : Build No : MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 2015/01/04 - 22:15:59 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:15:59 : ESN : B0000000 2015/01/04 - 22:15:59 : Prepairing... OK..OK..OK..OK..OK..OK 2015/01/04 - 22:16:21 : Writing 'EFS' Item... OK..OK 2015/01/04 - 22:16:28 : Writing 'NVM' Item... OK 2015/01/04 - 22:16:28 : Writing 'NVM (SIM1)' Item... OK 2015/01/04 - 22:16:28 : Writing 'NVM (SIM2)' Item... OK 2015/01/04 - 22:16:31 : Writing 'Provisioning' Items... OK 2015/01/04 - 22:16:31 : Write QCN Procedure Finihed. 2015/01/04 - 22:16:32 : Rebooting... OK! 2015/01/04 - 22:16:32 : 2015/01/04 - 22:16:32 : 2015/01/04 - 22:16:32 : Operation Time: 00:07:49 2015/01/04 - 22:17:01 : Certificate Parameteres Retrived. 2015/01/04 - 22:17:01 : Writing Certificate Procedure Started. 2015/01/04 - 22:17:01 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:01 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/04 - 22:17:01 : 2- Return to General Tab Tap on Developer Options 2015/01/04 - 22:17:01 : 3- And Check 'Usb Debugging' ON 2015/01/04 - 22:17:01 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/04 - 22:17:01 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/04 - 22:17:01 : 6- (Install All Needed Driver) 2015/01/04 - 22:17:01 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:06 : Prepairing ...OK 2015/01/04 - 22:17:06 : Device Found! 2015/01/04 - 22:17:06 : Reading Phone Informations ... 2015/01/04 - 22:17:06 : 2015/01/04 - 22:17:06 : Model : SM-G900F 2015/01/04 - 22:17:06 : Android Version : 4.4.2 2015/01/04 - 22:17:06 : PDA Version : G900FXXU1ANG2 2015/01/04 - 22:17:06 : CS Version : G900FOJV1ANG2 2015/01/04 - 22:17:06 : Phone Version : G900FXXU1ANG2 2015/01/04 - 22:17:07 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:17:07 : S/N : R58F80P5H7F 2015/01/04 - 22:17:07 : Checking Root ...OK 2015/01/04 - 22:17:07 : Phone Root OK. Continue.. 2015/01/04 - 22:17:07 : Prepairing... Fail! 2015/01/04 - 22:17:07 : [Err:2] Cannot stat! 2015/01/04 - 22:17:07 : 2015/01/04 - 22:17:07 : Operation Time: 00:00:06 2015/01/04 - 22:17:12 : Certificate Parameteres Retrived. 2015/01/04 - 22:17:12 : Writing Certificate Procedure Started. 2015/01/04 - 22:17:12 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:12 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/04 - 22:17:12 : 2- Return to General Tab Tap on Developer Options 2015/01/04 - 22:17:12 : 3- And Check 'Usb Debugging' ON 2015/01/04 - 22:17:12 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/04 - 22:17:12 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/04 - 22:17:12 : 6- (Install All Needed Driver) 2015/01/04 - 22:17:12 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:17 : Prepairing ...OK 2015/01/04 - 22:17:17 : Device Found! 2015/01/04 - 22:17:17 : Reading Phone Informations ... 2015/01/04 - 22:17:17 : 2015/01/04 - 22:17:17 : Model : SM-G900F 2015/01/04 - 22:17:17 : Android Version : 4.4.2 2015/01/04 - 22:17:17 : PDA Version : G900FXXU1ANG2 2015/01/04 - 22:17:17 : CS Version : G900FOJV1ANG2 2015/01/04 - 22:17:18 : Phone Version : G900FXXU1ANG2 2015/01/04 - 22:17:18 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:17:18 : S/N : R58F80P5H7F 2015/01/04 - 22:17:18 : Checking Root ...OK 2015/01/04 - 22:17:18 : Phone Root OK. Continue.. 2015/01/04 - 22:17:18 : Prepairing... Fail! 2015/01/04 - 22:17:18 : [Err:2] Cannot stat! 2015/01/04 - 22:17:18 : 2015/01/04 - 22:17:18 : Operation Time: 00:00:08 2015/01/04 - 22:17:22 : Certificate Parameteres Retrived. 2015/01/04 - 22:17:22 : Writing Certificate Procedure Started. 2015/01/04 - 22:17:22 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:22 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/04 - 22:17:22 : 2- Return to General Tab Tap on Developer Options 2015/01/04 - 22:17:22 : 3- And Check 'Usb Debugging' ON 2015/01/04 - 22:17:22 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/04 - 22:17:22 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/04 - 22:17:22 : 6- (Install All Needed Driver) 2015/01/04 - 22:17:22 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:27 : Prepairing ...OK 2015/01/04 - 22:17:27 : Device Found! 2015/01/04 - 22:17:27 : Reading Phone Informations ... 2015/01/04 - 22:17:27 : 2015/01/04 - 22:17:27 : Model : SM-G900F 2015/01/04 - 22:17:27 : Android Version : 4.4.2 2015/01/04 - 22:17:27 : PDA Version : G900FXXU1ANG2 2015/01/04 - 22:17:27 : CS Version : G900FOJV1ANG2 2015/01/04 - 22:17:27 : Phone Version : G900FXXU1ANG2 2015/01/04 - 22:17:28 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:17:28 : S/N : R58F80P5H7F 2015/01/04 - 22:17:28 : Checking Root ...OK 2015/01/04 - 22:17:28 : Phone Root OK. Continue.. 2015/01/04 - 22:17:28 : Prepairing... Fail! 2015/01/04 - 22:17:28 : [Err:2] Cannot stat! 2015/01/04 - 22:17:28 : 2015/01/04 - 22:17:28 : Operation Time: 00:00:07 2015/01/04 - 22:17:31 : Certificate Parameteres Retrived. 2015/01/04 - 22:17:31 : Writing Certificate Procedure Started. 2015/01/04 - 22:17:31 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:31 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/04 - 22:17:31 : 2- Return to General Tab Tap on Developer Options 2015/01/04 - 22:17:31 : 3- And Check 'Usb Debugging' ON 2015/01/04 - 22:17:31 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/04 - 22:17:31 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/04 - 22:17:31 : 6- (Install All Needed Driver) 2015/01/04 - 22:17:31 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:36 : Prepairing ...OK 2015/01/04 - 22:17:36 : Device Found! 2015/01/04 - 22:17:36 : Reading Phone Informations ... 2015/01/04 - 22:17:36 : 2015/01/04 - 22:17:36 : Model : SM-G900F 2015/01/04 - 22:17:36 : Android Version : 4.4.2 2015/01/04 - 22:17:36 : PDA Version : G900FXXU1ANG2 2015/01/04 - 22:17:36 : CS Version : G900FOJV1ANG2 2015/01/04 - 22:17:36 : Phone Version : G900FXXU1ANG2 2015/01/04 - 22:17:36 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:17:36 : S/N : R58F80P5H7F 2015/01/04 - 22:17:37 : Checking Root ...OK 2015/01/04 - 22:17:37 : Phone Root OK. Continue.. 2015/01/04 - 22:17:37 : Prepairing... Fail! 2015/01/04 - 22:17:37 : [Err:2] Cannot stat! 2015/01/04 - 22:17:37 : 2015/01/04 - 22:17:37 : Operation Time: 00:00:07 2015/01/04 - 22:17:40 : Certificate Parameteres Retrived. 2015/01/04 - 22:17:40 : Writing Certificate Procedure Started. 2015/01/04 - 22:17:40 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:40 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/04 - 22:17:40 : 2- Return to General Tab Tap on Developer Options 2015/01/04 - 22:17:40 : 3- And Check 'Usb Debugging' ON 2015/01/04 - 22:17:40 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/04 - 22:17:40 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/04 - 22:17:40 : 6- (Install All Needed Driver) 2015/01/04 - 22:17:40 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:17:45 : Prepairing ...OK 2015/01/04 - 22:17:45 : Device Found! 2015/01/04 - 22:17:45 : Reading Phone Informations ... 2015/01/04 - 22:17:45 : 2015/01/04 - 22:17:45 : Model : SM-G900F 2015/01/04 - 22:17:45 : Android Version : 4.4.2 2015/01/04 - 22:17:45 : PDA Version : G900FXXU1ANG2 2015/01/04 - 22:17:45 : CS Version : G900FOJV1ANG2 2015/01/04 - 22:17:45 : Phone Version : G900FXXU1ANG2 2015/01/04 - 22:17:45 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:17:46 : S/N : R58F80P5H7F 2015/01/04 - 22:17:46 : Checking Root ...OK 2015/01/04 - 22:17:46 : Phone Root OK. Continue.. 2015/01/04 - 22:17:46 : Prepairing... Fail! 2015/01/04 - 22:17:46 : [Err:2] Cannot stat! 2015/01/04 - 22:17:46 : 2015/01/04 - 22:17:46 : Operation Time: 00:00:07 |
01-05-2015, 07:52 | #3 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | 2015/01/04 - 22:08:43 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:08:43 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/04 - 22:08:43 : 2- Return to General Tab Tap on Developer Options 2015/01/04 - 22:08:43 : 3- And Check 'Usb Debugging' ON 2015/01/04 - 22:08:43 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/04 - 22:08:43 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/04 - 22:08:43 : 6- (Install All Needed Driver) 2015/01/04 - 22:08:43 : -------------------------------------------------------------------------------------- 2015/01/04 - 22:08:48 : Prepairing ...OK 2015/01/04 - 22:08:48 : Device Found! 2015/01/04 - 22:08:48 : Reading Phone Informations ... 2015/01/04 - 22:08:48 : 2015/01/04 - 22:08:48 : Model : SM-G900F 2015/01/04 - 22:08:49 : Android Version : 4.4.2 2015/01/04 - 22:08:49 : PDA Version : G900FXXU1ANG2 2015/01/04 - 22:08:49 : CS Version : G900FOJV1ANG2 2015/01/04 - 22:08:49 : Phone Version : G900FXXU1ANG2 2015/01/04 - 22:08:49 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:08:49 : S/N : R58F80P5H7F 2015/01/04 - 22:08:49 : Checking Root ...OK 2015/01/04 - 22:08:49 : Phone Root OK. Continue.. 2015/01/04 - 22:08:51 : Back Up Security AREA1... OK 2015/01/04 - 22:08:52 : Back Up Security AREA2... OK 2015/01/04 - 22:08:53 : Back Up Security AREA3... OK 2015/01/04 - 22:08:53 : Reading QCN Started! 2015/01/04 - 22:08:53 : Prepairing... OK 2015/01/04 - 22:08:53 : Searching for Phone ...OK 2015/01/04 - 22:08:53 : Preparing Phone on COM68 2015/01/04 - 22:08:53 : Reading Phone Information ... 2015/01/04 - 22:08:53 : Build No : MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 2015/01/04 - 22:08:53 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:08:53 : ESN : B0000000 2015/01/04 - 22:08:54 : Prepairing... OK..OK 2015/01/04 - 22:08:54 : Prepairing RFNV... OK 2015/01/04 - 22:08:57 : Retriving RFNV Items... OK 2015/01/04 - 22:09:12 : Reading RFNV Items Value... OK 2015/01/04 - 22:10:34 : Reading NV Items Value... OK 2015/01/04 - 22:12:56 : Reading NV SIM 1 Items Value... OK 2015/01/04 - 22:15:20 : Reading NV SIM 2 Items Value... OK 2015/01/04 - 22:15:40 : Retriving Provisioning Items... OK..OK..OK..OK 2015/01/04 - 22:15:40 : Read QCN Procedure Finished. 2015/01/04 - 22:15:42 : Reading QCN Finished! 2015/01/04 - 22:15:43 : Rebooting... OK! 2015/01/04 - 22:15:43 : 2015/01/04 - 22:15:43 : Waiting For Device... 2015/01/04 - 22:15:52 : Device Found! 2015/01/04 - 22:15:53 : Wiping EFS... OK..OK 2015/01/04 - 22:15:58 : Extracting QCN... OK.OK 2015/01/04 - 22:15:58 : Write QCN Procedure Started... 2015/01/04 - 22:15:58 : Searching for Phone ...OK 2015/01/04 - 22:15:58 : Preparing Phone on COM68 2015/01/04 - 22:15:59 : Reading Phone Information ... 2015/01/04 - 22:15:59 : Build No : MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 2015/01/04 - 22:15:59 : IMEI : 35xxxxxxxxxxxxxxx 2015/01/04 - 22:15:59 : ESN : B0000000 2015/01/04 - 22:15:59 : Prepairing... OK..OK..OK..OK..OK..OK 2015/01/04 - 22:16:21 : Writing 'EFS' Item... OK..OK 2015/01/04 - 22:16:28 : Writing 'NVM' Item... OK 2015/01/04 - 22:16:28 : Writing 'NVM (SIM1)' Item... OK 2015/01/04 - 22:16:28 : Writing 'NVM (SIM2)' Item... OK 2015/01/04 - 22:16:31 : Writing 'Provisioning' Items... OK 2015/01/04 - 22:16:31 : Write QCN Procedure Finihed. 2015/01/04 - 22:16:32 : Rebooting... OK! imei not gone |
01-05-2015, 08:26 | #6 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Use wipe efs without enable skip and then write cert or contact to me on sonork for wrtie cert Last edited by Asansam Box; 01-05-2015 at 08:38. |
